| » Kitchen Aid Gas Range |
Model Number: KGRA806PSS00 Brand: Kitchen Aid Age: 1 - 5 years
The off button for the oven does not work. All other functions seem to work fine. Is there any way to fix this other than replacing the entire control membrane?
Open the control panel and remove the control panel ribbon cable from the control board.
Check the tracks in the ribbon cable for a hairline cracks using a magnifier. Clean the connector on the board using an electronics contact cleaner or isopropyl alcohol and a tooth brush. Let the solvent to evaporate before reconnect the cable. If it would not help then the membrane switch has to be replaced. If you need the correct part number then post the color of the key pad. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KGRA806PSS00 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Kitchen Aid Range KEDC205YBL | Barbara Baptista | Oven Repair (including Ranges and Cooktops) | 1 | 12-14-2009 01:10 PM |
| kitchen range burner problem | wd4fny | Oven Repair (including Ranges and Cooktops) | 0 | 11-10-2009 04:52 PM |
| Kitchen Aid el. range door locked | sinitevo | Oven Repair (including Ranges and Cooktops) | 0 | 02-09-2009 03:57 PM |
| Kitchen Aid GAs Range | wstirrett | Oven Repair (including Ranges and Cooktops) | 1 | 09-22-2008 09:43 AM |
| kitchen aid range hood | blip | Oven Repair (including Ranges and Cooktops) | 0 | 04-16-2008 08:52 PM |
