wstirrett
#1 Posted : Sunday, September 21, 2008 9:43:06 AM(UTC)
wstirrett
I was in process of using the self cleaning feature and now the door is locked and have lost the display to the front mounted control panel. Since door is locked I can't access screws of front panel to check fuse or thermal cutout switch (I am assuming the power and display boards are behind this panel). I do have 120 volt power at plug. Any suggestions on how to override door lock or if I am looking in the right place?
libertyappl
#2 Posted : Monday, September 22, 2008 8:43:20 AM(UTC)
libertyappl
The thermal fused are located behind the rear panel on the range, unplug the unit and slide it out, turn off the gas too. remove the rear panel to located the fuses.
Nat
kitchen aid gas range (display fading) (Oven Repair (including Ranges and Cooktops))
by tlpru 8/30/2014 2:47:15 PM(UTC)
Kitchen Aid gas range - repair suggestions (Oven Repair (including Ranges and Cooktops))
by Rishavy 7/27/2013 8:33:48 AM(UTC)
Kitchen Aid Gas Range will not light (Oven Repair (including Ranges and Cooktops))
by fscel 7/22/2010 12:57:26 PM(UTC)
Kitchen Aid Gas Range (Oven Repair (including Ranges and Cooktops))
by Timinsf 10/24/2009 9:55:40 AM(UTC)
