This is a double oven. The upper oven and full cooktop work. The lower oven will not bake, broil or clean.
Have checked the voltage of the lower element, it is 25.0. Looking for a manual for this old appliance. No luck @ GE. Probably 1974-1975 vintage.
Has a hinge at the bottom of the control panel, next to the upper oven. Cannot see how to open it. Think there may be a fuse panel/switches in there.
Any advice would be appreciated.
