ridenroaddog
#1 Posted : Monday, December 9, 2013 11:06:59 AM(UTC)
ridenroaddog
I think the oven control board is out. The elements are good they ohm out, I only have 120v to elements (ground to each side of element) The stove top burners work, just no oven elements will not heat up.
#2 Posted : Tuesday, December 10, 2013 3:34:46 AM(UTC)
Parts for Frigidaire FEFL79HBB Range - AppliancePartsPros.com
Here is the tech sheet.
http://manuals.frigidaire.com/p...ingfield/316519936en.pdf
I agree with you that the control board is the most likely culprit.
I would unplug the unit and check the wires from the control board to the elements just to be sure they are OK.
If OK I would replace the control board.
You may also need a control overlay. Often they do not come off without some damage. Warming it up with a air dryer sometimes loosens the glue enough to get it off OK.
I am assuming that the oven stays in preheat and never comes ready.
BENZICAVE
#3 Posted : Wednesday, December 11, 2013 10:38:48 AM(UTC)
BENZICAVE
SOUNDS LIKE YOU HAVE TO MAKE SURE SOMEONE CAN SHOW YOU WHERE TO PUT THE WIRES SO THEY ARE ON DIFERENT PHASES!!!240 REQUIRES 120 COMING OFF TWO SEPERATE PHASES
1960's Oven Repair - Need model # (Oven Repair (including Ranges and Cooktops))
by jarla 12/13/2020 10:48:51 AM(UTC)
GE oven repair (Oven Repair (including Ranges and Cooktops))
by arshlo 12/10/2016 7:51:10 AM(UTC)
Oven Repair (Oven Repair (including Ranges and Cooktops))
by ANTHONYMAYWEATHERS 8/5/2013 4:45:40 PM(UTC)
by miguel 2 4/14/2013 10:06:22 AM(UTC)
Frigidaire Oven Repair Problem (Oven Repair (including Ranges and Cooktops))
by PetraMarion 2/25/2013 4:58:33 AM(UTC)
by johnthrasher45 2/9/2013 12:04:31 PM(UTC)
by johnthrasher45 2/8/2013 10:04:38 AM(UTC)
Oven repair (Oven Repair (including Ranges and Cooktops))
by johnthrasher45 2/8/2013 3:57:12 AM(UTC)
by johnthrasher45 2/7/2013 11:59:12 AM(UTC)
Questioning my first Oven Repair (Oven Repair (including Ranges and Cooktops))
by morbe 1/4/2013 1:18:05 PM(UTC)
by artalba 12/16/2012 5:07:10 PM(UTC)
GE Oven Repair Question? (Oven Repair (including Ranges and Cooktops))
by ejprap 11/7/2012 4:30:59 AM(UTC)
by gettone 10/23/2012 6:08:08 AM(UTC)
amana oven repair (Oven Repair (including Ranges and Cooktops))
by woodrow 10/16/2012 2:18:10 PM(UTC)
by Barb129 9/10/2012 12:03:34 PM(UTC)
