After installing new control panel, oven lights will not turn off
Here are your parts Parts for Maytag MER6751AAW Range - AppliancePartsPros.comI am assuming that the lights that stay on are the interior/door open lights. Have you tried removing power from the unit for a couple minutes to see if it will reset? If yes then you probably received a bad control board as the lights are controlled through the board, see the attachment for the tech sheet. |
THIS FORUM IS DEAD!!!!!!! |
