Discuss
Oven does not heat
 in
Just a few days ago , our oven on our Fridgedaire Electric range stopped heating up. The stove top units and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven does not heat
  #1 (permalink)
Old 02-06-2008, 03:04 PM
rwgithefirst rwgithefirst is offline
Junior Member
rwgithefirst is on a distinguished road
Default Oven does not heat
Brand: Frigidaire   Age: 1 - 5 years
Just a few days ago , our oven on our Fridgedaire Electric range stopped heating up. The stove top units and broiler are functioning. When the oven is turned on, the temperature indicators, etc operate as usual, but the oven heating element does not glow. There is a persistant click, click, but little change in the oven temperature. HELP!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-06-2008, 05:03 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
possibly bake element is dead, check for damage to element, or unplug stove ,remove back panel+and do a continuity check on leads of element ,or check for 220 volts at element ,if voltage there replace element
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ge oven, low heat labdad Oven Repair (including Ranges and Cooktops) 0 01-23-2008 08:18 PM
Bosch 27" Dbl oven Powering on but no heat either oven badace Oven Repair (including Ranges and Cooktops) 0 12-02-2007 10:56 AM
Oven will not heat lznuk Oven Repair (including Ranges and Cooktops) 1 11-16-2007 06:09 PM
Oven won't heat ctlopez Oven Repair (including Ranges and Cooktops) 0 10-03-2007 09:47 AM
Oven doesn't heat up mistyw Oven Repair (including Ranges and Cooktops) 0 09-07-2007 10:47 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
