I'm getting and error code of F6E5. I tried replacing the control board and it did not correct problem. I am now in the process of trying a new switch board part #9763551. I'm pretty good at disconnecting and reconnecting everything however I cannot figure out how to disconnect the switch for the stove warmer. It's the little black push button on front of switch panel. Anyone know how to disconnect it? I don't want to break it. tammike attached the following image(s):
