David Childs
#1 Posted : Monday, April 23, 2012 10:24:34 AM(UTC)
David Childs
Hi i am Having a problem with my oven not keeping temp @ the right setting. Off somtimes by 50deg intermittently. I have changed the high limit switch and oven sensor. Checked bake element @40ohms
The control panel is my next fix correct? Or what else:confused:
Simon / APP Team
#2 Posted : Monday, April 23, 2012 3:54:11 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
After replacing the oven sensor check the connection between the sensor and the control board.
If everything checks OK - replace the control board.
Control board Part number: 74008952
Here are the breakdown diagrams and Replacement parts for Jenn-Air JMW9330DAB WALLOVEN- S/C MWAVE ELE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
oven temp off (Oven Repair (including Ranges and Cooktops))
by laurieat 4/11/2013 3:00:20 PM(UTC)
Oven temp off (Oven Repair (including Ranges and Cooktops))
by Snowcats 6/25/2009 2:23:20 PM(UTC)
Oven temp off 100 degrees (Oven Repair (including Ranges and Cooktops))
by S Brown 10/30/2008 6:44:37 AM(UTC)
Oven temp off by 50 degrees (Oven Repair (including Ranges and Cooktops))
by hs545 10/5/2007 1:54:33 AM(UTC)
