OVEN WILL NOT CONTROL TEMPERATURE AND WILL NOT COME UP TO SET TEMPERATURE. hAVE REPLACED COMPLETE THERMOSTAT AND CONTROL PN/AP4262343
Originally Posted by: amma OVEN WILL NOT CONTROL TEMPERATURE AND WILL NOT COME UP TO SET TEMPERATURE. hAVE REPLACED COMPLETE THERMOSTAT AND CONTROL PN/AP4262343 Hello Amma. Understand @ the thermostat replaced. Is the oven ignitor part # Part number: AP4092701
sparking? If so and it is still holding temperature called for then it is possible The oven pilot is not working properly. This is no longer availiable Part number: AP401656
Thank You.
