JIWatsonJr
#1 Posted : Friday, April 24, 2009 1:09:41 PM(UTC)
JIWatsonJr
My oven stopped heating. I turned off the circuit breaker then went to remove the bake element and noticed that one of the wire connectors was not connected. I pulled the back off the oven and noticed that the connector was burnt and around 1 inch of the wire was also burnt. The bake element still looks good except it is a little black where the connector slides on. Should I cut the wire and put a new connector on and try it or should I call a service repair person? Thanks.
Drags1998
#2 Posted : Friday, April 24, 2009 4:01:13 PM(UTC)
Drags1998
Clean up the end of the element, put on a new terminal on the wire and your back in business!!!!!!:)
#3 Posted : Saturday, April 25, 2009 1:35:45 AM(UTC)
Be sure to cut the wire back till you get nice clean copper.
Also the new connector should be rated for high current.
JIWatsonJr
#4 Posted : Monday, July 6, 2009 11:22:46 AM(UTC)
JIWatsonJr
I put a new connector on. Worked for a while. It burnt up again. What now?
Drags1998
#5 Posted : Monday, July 6, 2009 12:16:05 PM(UTC)
Drags1998
At this stage, I would replace the element and install a new terminal on the wire, Make SURE the new terminal is installed correctly and has a TIGHT connection on the new element!!!!:)
JIWatsonJr
#6 Posted : Monday, July 6, 2009 12:52:14 PM(UTC)
JIWatsonJr
Where can I find a connector rated for a high currrent? The one I used was for low voltage (something I had in the garage). The connector was fine but it burnt the wire off again. Can I take the element to get it tested or would that matter?
Drags1998
#7 Posted : Monday, July 6, 2009 12:57:32 PM(UTC)
Drags1998
I see your in Me. Email Me and I'll send you a couple. Drags1998@yahoo.com
ArmyPilot
#8 Posted : Tuesday, April 13, 2010 3:27:14 AM(UTC)
ArmyPilot
Try Home Depot or Lowes
Maytag Dryer No Heat - Burnt Wire - Causes? (Dryer Repair)
by RobH7 11/11/2012 6:56:49 PM(UTC)
burnt wire smell (Washer Repair)
by jason71 7/17/2012 12:33:28 AM(UTC)
burnt wires on bosch dishwasher (Dishwasher Repair)
by peteh 3/27/2012 5:49:46 AM(UTC)
Replaced a burnt wire ... should I be ok? (Heating, Ventilation, and Air Conditioning (HVAC))
by jasonnovak 8/28/2010 2:44:10 PM(UTC)
Burnt Wires Connecting Heater Coil (Dryer Repair)
by williamsvd 7/29/2010 9:42:11 AM(UTC)
Jenn-Air JCD2389DES - Burnt wire connections (Refrigerator & Freezer Repair)
by acsf2010 5/11/2010 3:54:58 PM(UTC)
burnt wire that connects to the power block (Dryer Repair)
by ArmyPilot 4/12/2010 5:34:09 PM(UTC)
by ArmyPilot 4/12/2010 5:32:20 PM(UTC)
Burnt wires (Dryer Repair)
by blur 11/7/2009 9:21:54 AM(UTC)
