Discuss
oven problem
 in
m#gy398lxpt00.when plugged in clock illuminates along with PF in red.all touch pads on control panel are dead except bake.when bake
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven problem
  #1 (permalink)
Old 02-02-2011, 07:48 AM
Junior Member
bmmc44@hotmail.com is on a distinguished road
Default oven problem
Brand: Whirlpool   Age: 1 - 5 years
m#gy398lxpt00.when plugged in clock illuminates along with PF in red.all touch pads on control panel are dead except bake.when bake is pressed PF goes out & both oven elements come on along with temp 350.temp cannot be changed.elements cannot be turned off except by unplugging range.i suspect control panel is defective but the electronic control is also a possibility.is there a way to narrow it down to one or the other as the customer is not going to go for replacing both.i had the electronic control on the bench(i repair consumer electronics for a living) & all components test ok.all solder also looks good.
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Oven Problem PatsyC Oven Repair (including Ranges and Cooktops) 1 07-02-2010 06:32 PM
Oven Problem tracy48 Oven Repair (including Ranges and Cooktops) 0 12-07-2009 05:45 AM
oven problem brokendown Oven Repair (including Ranges and Cooktops) 1 06-11-2009 10:06 PM
ge oven not working. Oven door lock problem? Deano1 Oven Repair (including Ranges and Cooktops) 6 11-10-2008 01:02 PM
Thanksgiving Oven Problem.....its still a Problem! rbmattila Oven Repair (including Ranges and Cooktops) 1 03-03-2008 09:05 AM
