Discuss
Need Replacement Probe Part Number
 in
I am unable to locate the model number on my GE double oven. The house was built in 1984 and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Need Replacement Probe Part Number
  #1 (permalink)
Old 12-16-2010, 11:43 PM
Junior Member
mthornell is on a distinguished road
Default Need Replacement Probe Part Number
Brand: GE   Age: More than 10 years
I am unable to locate the model number on my GE double oven. The house was built in 1984 and I suspect this is the original oven. I was able to cross reference the numbers on the bake and broil elements. I recently replaced both. Now I need to replace the temperature probe but I do not have the part number. It measures 10 3/4" long and here is what it looks like . . .
Ads By Google
  #2 (permalink)
Old 12-17-2010, 05:57 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Looks like this will be more that a modern temperature sensor.
Probably is an integral part of the oven thermostat.
Try to get a manufacturers number off the part.
__________________
  #3 (permalink)
Old 12-17-2010, 11:18 AM
Junior Member
Default
The two numbers on the probe are #PS235170 and PS235127
  #4 (permalink)
Old 12-17-2010, 11:25 AM
Junior Member
Default
The first part number cross referenced to AP2623073. Do I need the entire assembly or can the probe be ordered separately?
  #5 (permalink)
Old 12-17-2010, 11:46 AM
Senior Expert
APP Volunteer
Default
It must be purchased as an assembly.
The probe cannot be separated from the thermostat.
__________________
  #6 (permalink)
Old 01-04-2011, 10:42 AM
Junior Member
Default Part Numbers On Probe
Read more: Need Replacement Probe Part Number
http://forum.appliancepartspros.com
  #7 (permalink)
Old 01-04-2011, 01:53 PM
Senior Expert
APP Volunteer
Default
PS235170 is
Part number: AP2623073
PS235127 is
Part number: AP2633815
Looking at the models this is used on they all are gas units.
I cannot explain why it has both numbers.
Perhaps compare the above with the one in the unit.
If you click on the first picture it will give you more views.
Also mention this when calling AppliancePartsPros, they may have a better description.
__________________
  #8 (permalink)
Old 01-04-2011, 02:04 PM
Junior Member
Default
Thank you so much
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Looking for a part number pmanmiles Refrigerator & Freezer Repair 0 06-13-2010 03:08 PM
Looking for part number BarrySG Oven Repair (including Ranges and Cooktops) 1 10-03-2009 03:37 AM
Need Replacement Part Number PaulHo Microwave Repair 0 08-29-2009 01:05 PM
Need part number - Oven Temp. Probe djarstfer Oven Repair (including Ranges and Cooktops) 1 08-04-2009 04:59 PM
Looking for Part Number Churn Dishwasher Repair 1 03-02-2009 01:25 PM
