I need to know why the right side of my control pad works which is the time section works and the left side which is oven section does not work.Do I need to replace the whole pad or some other electrical parts. The oven does not work but the time pad is working. The range is working fine in tems of burner ignition and can be used for top cooking. Thank you in advance
