Our oven does not work properly. I have checked the wiring and the elements. I can see no obvious places to suspect in the wiring, and I checked the elements with a voltmeter both for continuity and for shorting from the wire to the outer shell. Each element read about 20-22 ohms on a 200 ohm scale. I ordered and received a replacement control but find that it does not work. Since I waited too long to install it, Sears will not allow me to return it..Anyone have any other ideas??
Originally Posted by: quester ...Our oven does not work properly... Can you be more specific on the problem, please? Gene.
