Discuss
Whirlpool microwave blows fuses
 in
Microwave Repair
The microwave is part of an oven/microwave combo, the microwave stopped working immediately on start up and I heard
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Whirlpool microwave blows fuses
  #1 (permalink)
Old 01-23-2008, 08:29 PM
jclawman jclawman is offline
Junior Member
jclawman is on a distinguished road
Default Whirlpool microwave blows fuses
Model Number: RM765pxbb2   Brand: Whirlpool   Age: More than 10 years
The microwave is part of an oven/microwave combo, the microwave stopped working immediately on start up and I heard an audible pop that sounded like fuse blowing. I opened up the unit, found the fuse, ordered a new one (for $17!!) put the new one in and the unit powered up and allowed me to set a cook time but as soon as I pushed start it immediately blew the new fuse as well. Obviously, there is some other issue here any help is much appreciated!
In case it matters I will say that the new fuse came as a kit and included a "monitor" switch. The only problem is that the unit has three switches of this type in the door lock mechanism. I tested all three switches and they all seemed to be working correctly, so I replaced one arbitarily.
Finally, I bought the switch and fuse from this website and am a little upset with myself for blowing it in seconds.... can this fuse, a Bussman SC-20 Time Delay be purchased by itself?
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #3 (permalink)
Old 01-27-2008, 03:13 PM
ripleys ripleys is offline
Senior Expert
APP Volunteer
ripleys is on a distinguished road
Default
A bad door switch usually blows the fuse when the door is either opened or closed. Sounds to me like you have a problem with the high voltage section of your microwave e.g magnetron, capacitor, diode, HV transformer. I would suggest if you want to keep this microwave, get it diagnosed by a qualified service technician so you only replace the part that is required. Too many people try and fix these things just by replacing part after part after part and you end up spending a lot of unneccesary money to try and solve the problem.
  #4 (permalink)
Old 01-27-2008, 04:22 PM
RegUS_PatOff RegUS_PatOff is offline
Member
RegUS_PatOff is on a distinguished road
Default
the monitor switch interacts with the two interlock switches and will blow the fuse if either one of the interlock switches don't work (at the correct time).
monitor switch (red actuator) location on previous link
interlock switches (black actuator) Part Details - WHIRLPOOL Door interlock switch kit (2-pack), part number: AP3109474
#2 & #2 in this diagram:
http://www.appliancepartspros.com/se...neplpl15jj.gif
schematic:
File Type: pdf Pages from Tech%20Sheet%20-%203182395.pdf (31.7 KB, 11 views)
  #5 (permalink)
Old 01-27-2008, 06:13 PM
Junior Member
Default
Thanks to you both for the info!! Particularly the schematic, any chance you have the whole thing or could direct me to where I could find it? I did end up taking the unit to a repair place to be diagnosed and the guy was looking for the wiring diagram but we could not find one any where in the unit. Thanks again.
  #6 (permalink)
Old 01-27-2008, 06:46 PM
Member
Default
I don't have the manual, the schematic was just 1 of 2 sheets of a similar model.
there is more info on the Sears website http://www3.sears.com/Paul/model_sea...num=RM765pxbb2
give him these websites and print out the above messages.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Blows Fuse on Startup pcfucci Microwave Repair 0 01-04-2008 08:16 PM
Getting To Fuses DDY Microwave Repair 0 12-03-2007 11:34 AM
freezer blows cold then hot tambo Refrigerator & Freezer Repair 0 11-12-2007 04:59 AM
Are fuses replaceable on KitchenAid control panel? SomeOtherGuy Oven Repair (including Ranges and Cooktops) 0 10-13-2007 08:37 AM
My dryer blows hot air but doesn't turn. staceyo Dryer Repair 1 07-26-2007 08:45 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
