Discuss
Heat stopped last night
 in
Heating, Ventilation, and Air Conditioning (HVAC)
My Bryant furnace stopped working in the middle of the night. Woke up to a cold house. I have tried
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Heat stopped last night
  #1 (permalink)
Old 01-16-2016, 11:25 AM
Junior Member
xxxshiftxxx is on a distinguished road
Default Heat stopped last night
Brand: -other-   Age: 5 - 10 years
I have tried resetting the furnace by turning off power for a minute then trying again. Didn't work. The thermostat clicks and sends the call to heat, but nothing happens at the furnace.
I am not receiving any error codes. Just a solid red light indicating I have power.
I have disconnected the line from the pressure switch and blew through it. No resistance, clear.
Checked drain pan, clear no water.
Cleaned flame sensor with sandpaper.
Any ideas? The no error code is what is confusing me.
Thanks!
  #2 (permalink)
Old 01-24-2016, 03:01 PM
Junior Member
kjoshua48 is on a distinguished road
Smile
Check fuse on ICM (Circuit board)... You might be need replace ICM..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE microwave won't heat and turntable stopped vinceseg Microwave Repair 0 06-26-2012 06:17 AM
Oven will not heat up; worked last night wenmags Oven Repair (including Ranges and Cooktops) 0 11-15-2009 12:18 PM
(night)light under overhead microwave has stopped alfieonline Microwave Repair 1 04-15-2009 03:12 PM
No Heat While Turning, Heat When Stopped thou msg2008 Dryer Repair 1 08-07-2008 05:08 AM
Oven stopped heat after self clean ED31 Oven Repair (including Ranges and Cooktops) 1 06-01-2008 10:12 PM
