Hi, I'm having a problem with my Kenmore electric dryer. I've replaced the door swith and the thermal fuse (which I think needs replaced again) and the dryer started. My wife stated that the timer was set at 70 minutes but the buzzer went off in approx. 20 minutes and the dial was in the off position on the auto dry side of the timer dial. She set the time again with the same results except that the dial was in the middle of the auto dry cycle and the dryer would not start. Do I need a new timer or are the thermostats messed up?
