princess1983
#1 Posted : Sunday, February 7, 2010 1:51:31 PM(UTC)
princess1983
I just had the heating element put in and it worked. Now it will not start. We have checked all areas to juice.
#2 Posted : Monday, February 8, 2010 1:21:30 AM(UTC)
Replacement parts for rex3514rqo models | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf
[COLOR="Blue"]We have checked all areas to juice[/COLOR]
I am assuming that you have both 120 volts side and 240 between the sides.
Start circuit is fairly straight forward.
Does the interior light work? Also check that it shuts off when the door is closed.
If OK
I would check the thermal fuse in the motor circuit.
This is the one on the blower assembly, Item 23 in Section 3.
If blown replace it ASAP as it is a critical safety device.
If the fuse is OK
I would then check the door switch and the push to start switch.
Also if blown be sure to clean/check your vent system, this is the most common cause of it blowing.
Also clean/check the blower.
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Thermador oven won't start self clean (Oven Repair (including Ranges and Cooktops))
by beb123 2/6/2024 7:34:41 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Washer cycle won't start, motor just buzzes (Washer Repair)
by Guest 4/6/2023 4:46:53 PM(UTC)
Samsung DV42H5200EW/A3 Dryer makes loud buzzing noise and won't start unless (Dryer Repair)
by bvon 4/3/2023 9:46:22 PM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Samsung washing machine won't start (Washer Repair)
by Guest 11/14/2022 7:56:18 AM(UTC)
Maytag MDBH985AWS Won't Start Motor Humming (Dishwasher Repair)
by pdmac00 10/11/2022 12:48:23 PM(UTC)
Whirlpool WTW7500gc0 has power but won't start (Washer Repair)
by Guest 2/27/2022 2:52:51 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
dryer WED8300swo won't start (Dryer Repair)
by Guest 10/26/2021 10:24:13 AM(UTC)
Maytag LAT9600AAW Won't Start (Washer Repair)
by Guest 8/28/2021 6:11:33 AM(UTC)
Maytag washer (lsg7806aae) wills water but won't start (Washer Repair)
by uteng.cheang@gmail.com 8/18/2021 12:43:36 PM(UTC)
