Discuss
Dryer will not start
 in
Dryer Repair
I dryed a load, i was gona restart to heat clothes up and it would not start back up...that was
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will not start
  #1 (permalink)
Old 01-08-2010, 09:44 AM
Junior Member
CMT13 is on a distinguished road
Default Dryer will not start
Model Number: ADE20N3V   Brand: Admiral   Age: 5 - 10 years
I dryed a load, i was gona restart to heat clothes up and it would not start back up...that was a few days ago...still will not start...need to know if the door or timer.
Ads By Google
Related Models
Admiral ADE20N3V Dryer - Ele
Admiral ADE25K3A Dryer - Ele
Admiral ADE25K3H Dryer - Ele
Admiral ADE25K3W Dryer - Ele
Admiral ADE26K3A Dryer - Ele
Admiral ADE26K3H Dryer - Ele
Admiral ADE26K3W Dryer - Ele
Maytag ADE308 Dryer - Ele
Maytag ADE309 Dryer - Ele
Maytag ADE408 Dryer - Ele
Maytag ADE409 Dryer - Ele
Maytag ADE608 Dryer - Ele
Admiral ADE7000AYW Dryer - Ele
Admiral ADE7005AKW Dryer - Ele
Admiral ADE7005AYW Dryer - Ele
Maytag ADE808 Dryer - Ele
Admiral ADE9000AYW Dryer - Ele
Admiral ADE9005AGW Dryer - Ele
Whirlpool ADF07520
Whirlpool ADF07521
Whirlpool ADF07522
Whirlpool ADF10020
Whirlpool ADF10220
Whirlpool ADF11021
Whirlpool ADF12020
Whirlpool ADF12540
Whirlpool ADF13520
Whirlpool ADF13521
Whirlpool ADF13522
Whirlpool ADF13523
Whirlpool ADF17040
Whirlpool ADF18040
Whirlpool ADF18041
Whirlpool ADF18043
Whirlpool ADF18044
Whirlpool ADF18240
Whirlpool ADF21240
Whirlpool ADF21340
Whirlpool ADF21342
Whirlpool ADF21343
Whirlpool ADF29040
Whirlpool ADF29041
Whirlpool ADF29042
Whirlpool ADF29043
Whirlpool ADFC6320
Whirlpool ADFC6321
Whirlpool ADFC6322
Whirlpool ADFE1240
Whirlpool ADFE1241
Whirlpool ADFE1242
Whirlpool ADFE1540
Whirlpool ADFE1541
Whirlpool ADFE1542
Whirlpool ADFE1830
Whirlpool ADFE1831
Whirlpool ADFH0720
Whirlpool ADFH0721
Whirlpool ADFH2130
Whirlpool ADFP5020
Whirlpool ADFP5021
Whirlpool ADFP5022
Whirlpool ADFP5023
Whirlpool ADFP5520
Whirlpool ADFP6021
Whirlpool ADFP6022
Whirlpool ADFP8020
Whirlpool ADFP8021
Whirlpool ADFR1240
Whirlpool ADFS1020
Whirlpool ADFS1021
Whirlpool ADFS6020
Whirlpool ADFS6021
Whirlpool ADFS8020
Whirlpool ADFS8021
Whirlpool ADFS8022
Whirlpool ADFW0940
Whirlpool ADFW0941
Whirlpool ADFW0942
Whirlpool ADFW1240
Whirlpool ADFW1241
Whirlpool ADFW1242
Whirlpool ADFW1540
Whirlpool ADFW1541
Whirlpool ADFW1542
Whirlpool ADFW1543
Whirlpool ADFW1544
Maytag ADG107 Dryer - Gas
Admiral ADG20K2A Dryer - Gas
Admiral ADG20K2H Dryer - Gas
Admiral ADG20K2W Dryer - Gas
Admiral ADG20K3 Dryer - Gas
Admiral ADG20K3A Dryer - Gas
Admiral ADG20K3H Dryer - Gas
Admiral ADG20K3V Dryer - Gas
Admiral ADG20K3W Dryer - Gas
Admiral ADG20K4 Dryer - Gas
Admiral ADG20K4A Dryer - Gas
Admiral ADG20K4H Dryer - Gas
Admiral ADG20K4W Dryer - Gas
Admiral ADG20L1A Dryer - Gas
Admiral ADG20L1H Dryer - Gas
Admiral ADG20L1W Dryer - Gas
Admiral ADG20L2A Dryer - Gas
Admiral ADG20L2H Dryer - Gas
Admiral ADG20L2W Dryer - Gas
Admiral ADG20L4 Dryer - Gas
Admiral ADG20L4A Dryer - Gas
Admiral ADG20L4H Dryer - Gas
Admiral ADG20L4W Dryer - Gas
Admiral ADG20M3V Dryer - Gas
Admiral ADG20N3V Dryer - Gas
Maytag ADG308 Dryer - Gas
Maytag ADG309 Dryer - Gas
Maytag ADG408 Dryer - Gas
Maytag ADG409 Dryer - Gas
Maytag ADG608 Dryer - Gas
Admiral ADG7000AWW Dryer - Gas
Admiral ADG7005AWW Dryer - Gas
Maytag ADG808 Dryer - Gas
Admiral ADG9000AWW Dryer - Gas
  #2 (permalink)
Old 01-09-2010, 04:57 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for ADMIRAL ADE20N3V Dryer - Ele | AppliancePartsPros.com
Since you did not mention it, I am assuming the unit seems totally dead re: no noise at all when you try to start it.
Try flipping your breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker.
If this does nothing check the voltage at the plug
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral, both should be 120 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip
IF OK
Plug the unit in and check for the correct voltage at the terminal strip.
Be careful 240 volts is lethal !!!
If OK
Then at the top of the list is the thermal fuse (Item 5 in Section 4)
If it is blown you have to find out what caused it to go.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, shopuld be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the heater is OK then I would also replace the hi-limit thermostat as this should have regulated the temperature so that the fuse did not blow. As you can see in the parts that it comes with one Item 5 in Section 4.
You still have to find the cause.
It could be:
A dirty/loose blower wheel
A dirty vent system or it's outside louvers are not opening.
A bad cycling (control) thermostat. Note this is a 4 connector thermostat.
One set is the contacts. The other set is the internal heater, should be around 25,000 ohms. This is used to give you different heat settings.
Also high on the list is the start switch and the door switch.
Then the timer and then the motor
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
whirlpol dryer won't start-just hums when I push the start button bdubois Dryer Repair 27 02-18-2010 07:36 PM
dryer start but stops when I release start button vchss360 Dryer Repair 7 10-20-2009 03:46 AM
Kenmore Dryer won't start unless PTS (push to start) button depressed and held trp Dryer Repair 1 06-07-2009 06:13 AM
dryer start button noise - dryer won't run brhodes58 Dryer Repair 6 03-14-2009 02:11 PM
