vassarrepair
#1 Posted : Thursday, February 2, 2017 6:32:18 AM(UTC)
vassarrepair
Dryer will not start, light does not come on. Lint build up found in lint duct housing but not inhibiting the blower wheel. AC to the dryer is good. Thermal fuse at 0 ohms. Continuity on door switch is good. High limit thermostat is 0 ohms out of circuit. Control thermostat is 0 ohms/28k ohms out of circuit. Heating element is 11 ohms out of circuit with no short to case. Belt is intact. Any other testing that might lead me to faulty part? Any suggestions for repair?
PNWDrew
#2 Posted : Monday, February 6, 2017 8:43:06 PM(UTC)
PNWDrew
So this has the operating thermo down on the blower and a safety and thermal fuse up on the heater box right? If all those pass then check the Push To Start switch for continuity when pushed.
The only safety that should stop the motor is the thermal fuse at the heater.
Also you have 120v to ground and neutral on both on L1 and L2? not just 240v across L1 and L2? If so you'll have fun tracing where you lose it.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
Maytag Stackabl Dryer will not start, Makes the dryer Buzzing sound LSE7806ace (Dryer Repair)
by mdmitchell 6/29/2014 11:08:33 AM(UTC)
