je24995
#1 Posted : Sunday, December 13, 2009 11:19:31 AM(UTC)
je24995
My duet 9250 dryer runs through the cycle but no heat. I went through the troubleshooting in the manual but everything seems to check out ok. Could it be the ckt board? Its about $200 so I cant afford to throw parts like that at it if its not it.
TheDragon
#2 Posted : Wednesday, December 16, 2009 9:46:15 AM(UTC)
TheDragon
I had same situation (passed all tests)
so I took the chance and bought the CB ($45)
they offered to take it back if that was NOT my problem
but before I sent it back - I go a heater relay ($30)
that fixed it (I am debating on returning the CB ( cause my original had a small burned resistor - common problem on my model)
not sure what failed first, the CB (if at all) or the heater relay
je24995
#3 Posted : Wednesday, December 16, 2009 11:36:59 AM(UTC)
je24995
Where did u order from? i found one for $200? I even jumpered out the heater relay on the board. still wont work.
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Dryer runs but no heat. (Dryer Repair)
by Elarde 6/18/2015 1:17:00 AM(UTC)
Electric dryer runs but no heat (Dryer Repair)
by M hatcher 1/28/2015 2:49:23 PM(UTC)
new kenmore dryer runs but no heat (Dryer Repair)
by crazyhouse 11/19/2012 4:56:14 PM(UTC)
GE gas dryer runs but no heat. (Dryer Repair)
by rroy58 11/19/2012 3:07:23 PM(UTC)
Dryer runs but no heat (Dryer Repair)
by barglancy 9/26/2011 4:44:08 PM(UTC)
another "dryer runs but no heat" problem (Dryer Repair)
by Rayman812 6/27/2011 7:31:38 PM(UTC)
Whirlpool Gas Dryer Runs But No Heat (Dryer Repair)
by cybolt 3/10/2011 8:08:45 PM(UTC)
by sdean 2/8/2011 2:05:25 PM(UTC)
Gas dryer runs but no heat (Dryer Repair)
by pastrychef 1/31/2011 9:02:20 PM(UTC)
Gas dryer runs but no heat. (Dryer Repair)
by peter g 1/7/2011 9:32:32 PM(UTC)
by glenn906 7/1/2010 11:14:54 AM(UTC)
Frigidare gas dryer runs but no heat or ignition (Dryer Repair)
by hanzi1 5/21/2010 12:06:37 PM(UTC)
by katyld 1/27/2010 3:06:34 PM(UTC)
Roper,dryer runs but no heat. (Dryer Repair)
by JOE BLACK 9/19/2009 1:39:36 PM(UTC)
