Discuss
Thermostat problems
 in
Dryer Repair
Dryer often runs controlled by high limit thermostat instead of the air output thermostat. This prevents the dryer from stopping
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Thermostat problems
  #1 (permalink)
Old 12-04-2009, 05:16 PM
Junior Member
randywapp is on a distinguished road
Default Thermostat problems
Model Number: LDG7334AAE   Brand: Maytag   Age: 5 - 10 years
Dryer often runs controlled by high limit thermostat instead of the air output thermostat. This prevents the dryer from stopping on the auto timer modes where the timer only advances when the air output thermostat opens. The vent pipe is fairly long (about 17 feet) which may be part of the problem. If the vent is absolutely clean, it will run on the right thermostat, but it seems that any lint at all in the vent will cause it to run on the high limit stat. Would it make sense to reduce the gas flow about 20% so that the high limit stat doesn't trip too soon? With full gas flow there is a lot of flame near the high limit stat. With the gas turned down a little, the temp in the burner should be lower, so the air output stat should get tripped before the high limit.
Does this make sense?
Thanks.
Related Models
Maytag LDG7334AAE DRYER- GAS
Maytag LDG7334AAL DRYER- GAS
Maytag LDG7334AAM DRYER- GAS
Maytag LDG7400 DRYER- GAS
Maytag LDG7400AAL DRYER- GAS
Maytag LDG7400AAW DRYER- GAS
Maytag LDG7400ABL DRYER- GAS
Maytag LDG7400ABW DRYER- GAS
Maytag LDG7480AAL DRYER- GAS
Maytag LDG7480AAW DRYER- GAS
Maytag LDG7480ABL DRYER- GAS
Maytag LDG7480ABW DRYER- GAS
Maytag LDG7500 DRYER- GAS
Maytag LDG7500AAE DRYER- GAS
Maytag LDG7500AAL DRYER- GAS
Maytag LDG7500AAM DRYER- GAS
Maytag LDG7500AAW DRYER- GAS
Maytag LDG7500ABE DRYER- GAS
Maytag LDG7500ABL DRYER- GAS
Maytag LDG7500ABM DRYER- GAS
Maytag LDG7500ABW DRYER- GAS
Maytag LDG7600 DRYER- GAS
Maytag LDG7600AAG DRYER- GAS
Maytag LDG7600AAL DRYER- GAS
Maytag LDG7600AAW DRYER- GAS
Maytag LDG7600ABL DRYER- GAS
Maytag LDG7600ABW DRYER- GAS
Maytag LDG7600AGG DRYER- GAS
Maytag LDG7600AGL DRYER- GAS
Maytag LDG7600AGW DRYER- GAS
Maytag LDG7800 DRYER- GAS
Maytag LDG7800AAL DRYER- GAS
Maytag LDG7800AAW DRYER- GAS
Maytag LDG7800ABL DRYER- GAS
Maytag LDG7800ABW DRYER- GAS
Maytag LDG8000 DRYER- GAS
Maytag LDG8000AAL DRYER- GAS
Maytag LDG8000AAW DRYER- GAS
Maytag LDG8000ABL DRYER- GAS
Maytag LDG8000ABW DRYER- GAS
Maytag LDG810 DRYER- GAS
Maytag LDG8200 DRYER- GAS
Maytag LDG8200AAE DRYER- GAS
Maytag LDG8200AAL DRYER- GAS
Maytag LDG8200AAW DRYER- GAS
Maytag LDG8200ABE DRYER- GAS
Maytag LDG8200ABL DRYER- GAS
Maytag LDG8200ABW DRYER- GAS
Maytag LDG8300 DRYER- GAS
Maytag LDG8300AAL DRYER- GAS
Maytag LDG8300AAW DRYER- GAS
Maytag LDG8304AAE DRYER- GAS
Maytag LDG8304AAL DRYER- GAS
Maytag LDG8304AAM DRYER- GAS
Maytag LDG8404AAE DRYER- GAS
Maytag LDG8404AAL DRYER- GAS
Maytag LDG8404AAM DRYER- GAS
Maytag LDG8404ABE DRYER- GAS
Maytag LDG8406AAE DRYER- GAS
Maytag LDG8406AAM DRYER- GAS
Maytag LDG8406ABE DRYER- GAS
Maytag LDG8410 DRYER- GAS
Maytag LDG8410AAE DRYER- GAS
Maytag LDG8410AAL DRYER- GAS
Maytag LDG8410AAW DRYER- GAS
Maytag LDG8410ABE DRYER- GAS
Maytag LDG8410ABL DRYER- GAS
Maytag LDG8410ABW DRYER- GAS
Maytag LDG8414AAE DRYER- GAS
Maytag LDG8414AAL DRYER- GAS
Maytag LDG8414AAM DRYER- GAS
Maytag LDG8416AAE DRYER- GAS
Maytag LDG8416AAM DRYER- GAS
Maytag LDG8420 DRYER- GAS
Maytag LDG8420AAL DRYER- GAS
Maytag LDG8420AAW DRYER- GAS
Maytag LDG8420ABL DRYER- GAS
Maytag LDG8420ABW DRYER- GAS
Maytag LDG8424AAE DRYER- GAS
Maytag LDG8424AAL DRYER- GAS
Maytag LDG8424AAM DRYER- GAS
Maytag LDG8424ABE DRYER- GAS
Maytag LDG8426AAE DRYER- GAS
Maytag LDG8426AAM DRYER- GAS
Maytag LDG8426ABE DRYER- GAS
Admiral LDG8426AGE DRYER- GAS
Admiral LDG8426EGE DRYER- GAS
Admiral LDG8426GGE DRYER- GAS
Maytag LDG8500 DRYER- GAS
Maytag LDG8500AAL DRYER- GAS
Maytag LDG8500AAW DRYER- GAS
Maytag LDG8506AAE DRYER- GAS
Maytag LDG8506AAM DRYER- GAS
Maytag LDG8600 DRYER- GAS
Maytag LDG8600AAL DRYER- GAS
Maytag LDG8600AAW DRYER- GAS
Maytag LDG8600ABL DRYER- GAS
Maytag LDG8600ABW DRYER- GAS
Maytag LDG8604AAE DRYER- GAS
Maytag LDG8604AAL DRYER- GAS
Maytag LDG8604AAM DRYER- GAS
Maytag LDG8606AAE DRYER- GAS
Maytag LDG8606AAM DRYER- GAS
Maytag LDG8616AAE DRYER- GAS
Maytag LDG8616AAM DRYER- GAS
Maytag LDG8624AAE DRYER- GAS
Maytag LDG8624AAL DRYER- GAS
Maytag LDG8624AAM DRYER- GAS
Maytag LDG8626AAE DRYER- GAS
Maytag LDG8626AAM DRYER- GAS
Maytag LDG8704AAE DRYER- GAS
Maytag LDG8704AAL DRYER- GAS
Maytag LDG8704AAM DRYER- GAS
Maytag LDG8706AAE DRYER- GAS
Maytag LDG8706AAM DRYER- GAS
Maytag LDG8804AAE DRYER- GAS
Maytag LDG8804AAL DRYER- GAS
Maytag LDG8804AAM DRYER- GAS
Maytag LDG882 DRYER- GAS
Maytag LDG8824AAE DRYER- GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
thermostat stockpicker2008 Refrigerator & Freezer Repair 1 06-25-2009 06:09 PM
Thermostat problems qJq Oven Repair (including Ranges and Cooktops) 0 06-01-2009 05:10 PM
One part causing many problems, or just lots of problems? Woogy Oven Repair (including Ranges and Cooktops) 1 10-07-2008 12:52 PM
bought new thermostat and heater thermostat and now won't heat at all mgilbert6 Dryer Repair 0 09-07-2008 09:58 AM
