Got this dryer at a yard sale. Told me it was propane. When I got home I hooked everything up.Turned the dryer on, tumbler worked and it fired. Hugh flame and not the right color for propane. So shut it downed. Got the part to change to propane, have not installed yet. The tumbler does not work at all when I turn the dryer on. How do I get to the burner to change the orifice? And shouldn't the tumbler work even if the gas is not hooked up? Thanks.
