Discuss
Maytag dryer won't start
 in
Dryer Repair
Hi, all. I have a Maytag that I bought in 1996. Over the years I have replaced several parts on
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag dryer won't start
  #1 (permalink)
Old 11-15-2017, 07:44 PM
Junior Member
eagle243 is on a distinguished road
Default Maytag dryer won't start
Model Number: LDE8604ACE   Brand: Maytag   Age: More than 10 years
Hi, all.
I have a Maytag that I bought in 1996. Over the years I have replaced several parts on it. This week, I replaced the motor because the bearings went out. Tonight after I finished the job, I started it and it ran fine for 30 minutes or so. I went to demo it to my wife, and it will not start.
I checked the start switch - it's fine (multimeter shows it to be a closed circuit).
I checked the thermal fuse - it's fine (multimeter shows it to be a closed circuit).
I checked the door switch - it's fine (multimeter shows it to be a closed circuit).
The unit has power.
I'm at a loss for what else to check Any ideas?
Maybe it's the function selector switch... but I wonder if I can still find that part.
Related Models
Maytag LDE8604ACE DRYER- ELE
Maytag LDE8604ACL DRYER- ELE
Maytag LDE8604ACM DRYER- ELE
Maytag LDE8604ADE DRYER- ELE
Maytag LDE8604ADL DRYER- ELE
Maytag LDE8604ADM DRYER- ELE
Maytag LDE8606ACE DRYER- ELE
Maytag LDE8606ACM DRYER- ELE
Maytag LDE8606ADE DRYER- ELE
Maytag LDE8616ACE DRYER- ELE
Maytag LDE8616ACM DRYER- ELE
Maytag LDE8624ACE DRYER- ELE
Maytag LDE8624ACL DRYER- ELE
Maytag LDE8624ACM DRYER- ELE
Maytag LDE8624ADE DRYER- ELE
Maytag LDE8626ACE DRYER- ELE
Maytag LDE8626ACM DRYER- ELE
Maytag LDE8626ADE DRYER- ELE
Maytag LDE8704ACE DRYER- ELE
Maytag LDE8704ACL DRYER- ELE
Maytag LDE8704ACM DRYER- ELE
Maytag LDE8706ACE DRYER- ELE
Maytag LDE8706ACM DRYER- ELE
Maytag LDE8706ADE DRYER- ELE
Maytag LDE8804ACE DRYER- ELE
Maytag LDE8804ACL DRYER- ELE
Maytag LDE8804ACM DRYER- ELE
Maytag LDE8804ADE DRYER- ELE
Maytag LDE882 DRYER- ELE
Maytag LDE8824ACE DRYER- ELE
Maytag LDE8824ACL DRYER- ELE
Maytag LDE8824ACM DRYER- ELE
Maytag LDE8824ADE DRYER- ELE
Maytag LDE8904ACE DRYER- ELE
Maytag LDE8904ACL DRYER- ELE
Maytag LDE8904ACM DRYER- ELE
Norge LDE9127A DRYER- ELE
Norge LDE9127H DRYER- ELE
Norge LDE9127W DRYER- ELE
Maytag LDE9206ACE DRYER- ELE
Maytag LDE9206ACM DRYER- ELE
Maytag LDE9206ADE DRYER- ELE
Maytag LDE9304ACE DRYER- ELE
Maytag LDE9304ACL DRYER- ELE
Maytag LDE9304ACM DRYER- ELE
Maytag LDE9304ADE DRYER- ELE
Maytag LDE9304ADL DRYER- ELE
Maytag LDE9304ADM DRYER- ELE
Maytag LDE9304AEE DRYER- ELE
Maytag LDE9306ACE DRYER- ELE
Maytag LDE9306ACM DRYER- ELE
Maytag LDE9306ADE DRYER- ELE
Maytag LDE9306ADM DRYER- ELE
Maytag LDE9306AEE DRYER- ELE
Maytag LDE9314ACE DRYER- ELE
Maytag LDE9314ACL DRYER- ELE
Maytag LDE9314ACM DRYER- ELE
Maytag LDE9314ADE DRYER- ELE
Maytag LDE9316ACE DRYER- ELE
Maytag LDE9316ACM DRYER- ELE
Maytag LDE9316ADE DRYER- ELE
Maytag LDE9334ACE DRYER- ELE
Maytag LDE9334ACL DRYER- ELE
Maytag LDE9334ACM DRYER- ELE
Maytag LDE9334ADE DRYER- ELE
Maytag LDE9606ACE DRYER- ELE
Maytag LDE9606ACM DRYER- ELE
Maytag LDE9606ADE DRYER- ELE
Maytag LDE9606ADM DRYER- ELE
Maytag LDE9606AEE DRYER- ELE
Maytag LDE9700 DRYER- ELE
Maytag LDE9700ACL DRYER- ELE
Maytag LDE9700ACW DRYER- ELE
Maytag LDE9700ADL DRYER- ELE
Maytag LDE9700ADW DRYER- ELE
Maytag LDE9701ACL DRYER- ELE
Maytag LDE9701ACW DRYER- ELE
Maytag LDE9701ADL DRYER- ELE
Maytag LDE9701ADW DRYER- ELE
Maytag LDE9800 DRYER- ELE
Maytag LDE9800ACL DRYER- ELE
Maytag LDE9800ACW DRYER- ELE
Maytag LDE9800ADL DRYER- ELE
Maytag LDE9800ADW DRYER- ELE
Maytag LDE9801ACL DRYER- ELE
Maytag LDE9801ACW DRYER- ELE
Maytag LDE9801ADL DRYER- ELE
Maytag LDE9801ADW DRYER- ELE
Maytag LDE9804ACE DRYER- ELE
Maytag LDE9804ACL DRYER- ELE
Maytag LDE9804ACM DRYER- ELE
Maytag LDE9804ADE DRYER- ELE
Maytag LDE9804ADL DRYER- ELE
Maytag LDE9804ADM DRYER- ELE
Maytag LDE9804AEE DRYER- ELE
Maytag LDE9806ACE DRYER- ELE
Maytag LDE9806ACM DRYER- ELE
Maytag LDE9806ADE DRYER- ELE
Admiral LDE9806GGE DRYER- ELE
Maytag LDE9814ACE DRYER- ELE
Maytag LDE9814ACL DRYER- ELE
Maytag LDE9814ACM DRYER- ELE
Maytag LDE9814ADE DRYER- ELE
Maytag LDE9824ACE DRYER- ELE
Maytag LDE9824ACL DRYER- ELE
Maytag LDE9824ACM DRYER- ELE
Maytag LDE9824ADE DRYER- ELE
Maytag LDE9900 DRYER- ELE
Maytag LDE9900ACL DRYER- ELE
Maytag LDE9900ACW DRYER- ELE
Maytag LDE9900ADL DRYER- ELE
Maytag LDE9900ADW DRYER- ELE
Maytag LDE9900BCL DRYER- ELE
Maytag LDE9900BCW DRYER- ELE
Maytag LDE9900BDL DRYER- ELE
Maytag LDE9900BDW DRYER- ELE
Maytag LDE9904ACE DRYER- ELE
Maytag LDE9904ACL DRYER- ELE
Maytag LDE9904ACM DRYER- ELE
Maytag LDE9904ADE DRYER- ELE
  #2 (permalink)
Old 11-15-2017, 10:32 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
The wiring diagram shows two thermal fuses. Always remove one wire when you test for continuity.
Parts for Maytag LDE8604ACE: Wiring Information-LDE8604ACX Parts - AppliancePartsPros.com
  #3 (permalink)
Old 11-16-2017, 05:15 AM
Junior Member
Default
Thanks.
This morning I found that it had tripped the breaker, so I reset that and went to try again. I ran it for about 10 minutes, then opened the door to confirm that it was hot. Closed the door and pushed start button: motor spun, but didn't catch. Released start button and pushed again: NOTHING. Checked breaker - breaker is not tripped, and I confirmed the unit still has power.
I'll check both thermal fuses (the one a second time, and the other a first time).
Thanks.
  #4 (permalink)
Old 11-19-2017, 11:59 AM
Junior Member
Default
Thanks for the reply. I checked the second thermal fuse, and it is fine too. I think I have figured out what's going on, but now I don't know what to do about it. Here's more info on this problem:
When the unit is cold, I can set the timer to a run setting (e.g., 50 minutes) and push start and have it start pretty quickly. If I let it run for a few minutes and then stop it and attempt to restart it, it progressively gets more difficult to start as I let it run longer, to the point that pushing the start button makes a noise in the motor but does not spin the drum. Not long after this, pushing the start button results in the motor not doing anything. Then, after a few minutes, without doing anything but wait, I can push start and the motor spins and starts the dryer.
The longer I wait between runs, the faster it is to start; my guess is that the longer I wait between runs, the cooler the motor is.
I am suspecting a thermal overload in the motor.
I have confirmed all of my connections. Specifically: I am coming from an S58NXEET-4784 and moving to a S58SVEET-7126. I followed the included instructions:
- grey lead connects to thermal protector tab
- red lead connects to pin 5
- blue lead connects to pin 1
- black lead connects to pin 2
- yellow lead connects to pin 6
I wonder if I got a faulty motor and that the centrifugal switch is not cutting over to the cooler "run" winding and is stuck on the hotter "start" winding.
Thanks for your help earlier, and for any guidance on tracking this down.
  #5 (permalink)
Old 11-21-2017, 12:44 PM
Junior Member
Default
Well, my issue turned out to be that the new motor was faulty. I replaced it today, and the dryer now works perfectly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer will not start Kabel69 Dryer Repair 5 11-06-2017 06:03 AM
Maytag Stackabl Dryer will not start, Makes the dryer Buzzing sound LSE7806ace mdmitchell Dryer Repair 9 07-26-2014 01:29 PM
Maytag dryer won't start Momof3boys3 Dryer Repair 0 04-22-2014 03:25 PM
Maytag dryer won't start crmullins Dryer Repair 3 07-18-2012 12:56 PM
Maytag Dryer won't start tmckeithan Dryer Repair 6 12-05-2011 12:54 AM
