Discuss
Kenmore electric dryer
 in
Dryer Repair
dryer runs, just no heat, replaced thermal fuse, wasn't thermal fuse, then replaced operating thermostat.... dryer worked great for about
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore electric dryer
  #1 (permalink)
Old 12-01-2016, 04:23 PM
Junior Member
carpenter83 is on a distinguished road
Default Kenmore electric dryer
Brand: Kenmore   Age: 5 - 10 years
dryer runs, just no heat, replaced thermal fuse, wasn't thermal fuse, then replaced operating thermostat.... dryer worked great for about 2 weeks, then no heat again... cleaned everything... do not want to spend another $45 on part to fail again... any ideas?
  #2 (permalink)
Old 12-01-2016, 09:33 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
I have lots of ideas, but need a model number to start with.
  #3 (permalink)
Old 12-02-2016, 05:15 PM
Junior Member
Default model #
That Guy, thanks for response. It is 110.62202100
  #4 (permalink)
Old 12-02-2016, 09:57 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Yours is fairly simple, heating element, thermal cutoff/fuse on element shell, thermostat, timer, motor start switch and the wires that connect everything up.
I usually start with the power coming in. Make sure you have 240 volts to the dryer. I look over all electrical connections, look for burnt connectors and discolored wires.
Check the heating element, thermal cutoff/ fuse, and cycling t-stat for continuity.
If they and the wiring in between are good check the timer.
timer WP3976582
heating element WP279838
thermal cutoff/fuse
279816
t-stat
3387134
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Electric Dryer johnhb Dryer Repair 2 09-30-2015 09:41 AM
Kenmore Electric Dryer - drum hits the top of the dryer. willow5000 Dryer Repair 1 02-15-2013 03:56 PM
kenmore he2 electric dryer kentheman Dryer Repair 1 10-04-2012 08:52 PM
Electric Kenmore Dryer nancy4240weber Dryer Repair 5 11-18-2009 05:22 PM
