Replaced drum bearing, cleaned the entire dryer, put it all back together, started the unit, ran fine, put the top back on, pushed it back in place, pushed the start button and nothing, the board is energizing the heat element relay but not the motor relay, door switch ok, thermal disc ok, thermister reading 53 ohms, no fault codes, but if it sits long enough the lights on the right side flash rapidly continuously, scratch my head at this point!
