skimlet
#1 Posted : Tuesday, March 18, 2014 9:16:41 AM(UTC)
skimlet
when i start the dryer the ignitor glows, the gas comes on and i get a flame, after ~30 seconds it shuts off. I have replaced the gas valve coils and the same thing happens. I jumpered out the high limit thermostat and the flame stayed on so I replaced the thermostat but the the flame turns off again after 30 seconds, so i jumpered out the thermostat and the flame stays on, I am at a loss as what to do next.
fairbank56
#2 Posted : Tuesday, March 18, 2014 9:26:57 AM(UTC)
fairbank56
Groups: Expert
Do not leave the hi limit thermostat bypassed. It is a safety device. Your dryer is overheating either because the operating thermostat is faulty or more likely, you have an air flow issue due to blockage from lint buildup either in the dryer venting system or the external exhaust duct.
Eric
skimlet
#3 Posted : Tuesday, March 18, 2014 9:32:41 AM(UTC)
skimlet
Eric
the vent is clear in the dryer and the duct is currently not hooked up so it might be the dryer cycling thermostat?
fairbank56
#4 Posted : Tuesday, March 18, 2014 9:59:05 AM(UTC)
fairbank56
Groups: Expert
So, you removed the lint chute to thoroughly check/clean inside of it as well as the blower housing? Also check to make sure the blower wheel is not spinning freely on the motor shaft. If all is good, then check the operating thermostat. It should open at 155° and close at 130°.
Whirlpool 3387134 Dryer Cycling Thermostat - AppliancePartsPros.com
Eric
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
LG dryer heat stops during load (Dryer Repair)
by Guest 4/15/2023 10:14:22 AM(UTC)
LG Dryer Heater Thermistor Error (Dryer Repair)
by Guest 11/16/2022 8:37:57 AM(UTC)
Dryer heating in timed cycle but now heating in oher cycles (Dryer Repair)
by bblossm 2/19/2022 4:32:16 PM(UTC)
Dryer heating sometimes (Dryer Repair)
by Guest 2/13/2022 4:07:15 PM(UTC)
Kenmore Dryer Heat and Run issue (Dryer Repair)
by IDConundrum 10/26/2020 7:06:47 PM(UTC)
Whirlpool dryer heats for a bit then stops (WGD6400SW1) (Dryer Repair)
by don_caruana 9/2/2020 6:35:54 PM(UTC)
Samsung Electric dryer heating issue (Dryer Repair)
by £∆Z€R* 6/18/2020 10:08:23 AM(UTC)
Gas Dryer heat cycles on and off (Dryer Repair)
by Al Lynch 4/23/2020 10:47:08 AM(UTC)
Kemore elite dryer heating coil not heating (Dryer Repair)
by kenmodel 1/27/2020 7:50:40 PM(UTC)
Samsung Dryer heats then stops working and begins beeping. (Dryer Repair)
by jmm0816 6/1/2019 5:54:04 AM(UTC)
Dryer Heats, but drum does not turn (Dryer Repair)
by tzmango 2/21/2019 1:47:43 PM(UTC)
Dryer heats up but takes too long to dry (Dryer Repair)
by bear0729 11/13/2018 6:35:10 AM(UTC)
Electric Admiral Dryer heating problems. (Dryer Repair)
by ShaneBurle24 7/12/2018 8:32:23 AM(UTC)
dryer heats but won't spin (Dryer Repair)
by nugentc 4/26/2018 8:09:40 AM(UTC)
