the display on the dryer is blank. i can get the dryer to work if i just press start after it receives info from the washer and it runs perfectly fine. however without the screen i cant get it to run any other cycles. is there any way to dry clothes by bypassing the touch screen. its like 400-500 bucks to replace.
paul
