JustinK
#1 Posted : Monday, March 25, 2013 9:07:23 AM(UTC)
JustinK
Hello, the other day my dryer just all of a sudden would not start. The timer switch works fine, and when I "push to start", it makes a buzzing noise as if it is sending electricity, but the drum does not move at all. I do not have an ohmmeter to test the current and money is a bit tight at the moment. Any suggestions?
Oh yeah, and it is a Capri model from Sears.
EDIT: If I hold the start button in for about ten seconds, it will make a click noise and then produce no sound at all as if something has been tripped. If I wait roughly a minute, it will make the buzzing noise again when I try to start it.
Originally Posted by: JustinK Go to Quoted Post
The complete model number is: 86910100 69101
Simon / APP Team
#2 Posted : Monday, March 25, 2013 9:39:15 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please provide the complete model number of the unit.
Simon.
JustinK
#3 Posted : Monday, March 25, 2013 12:56:41 PM(UTC)
JustinK
Oh, I am sorry, I did not notice that it continued.
Simon / APP Team
#4 Posted : Monday, March 25, 2013 1:11:19 PM(UTC)
Simon / APP Team
Groups: APP Team
Sears model will start with 3 numbers, then dot, then another 8 numbers.
Simon.
JustinK
#5 Posted : Monday, March 25, 2013 5:07:59 PM(UTC)
JustinK
Perhaps it is 110. 86910100
Somehow I'm failing at this.
The image of the service tag is attached just in case I'm hallucinating.
JustinK attached the following image(s):
Simon / APP Team
#6 Posted : Tuesday, March 26, 2013 9:44:17 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Try this:
Open the door, tape the door switch in closed position.
Set the timer on, push the start button and turn the tumbler. If the motor kicks in - replace it. (Motor start winding most likely is bad).
The motor Part number: 279827
Part number: 279827
Use the video clip for instructions.
Post the results.
Simon.
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Dryer won't start all the time (Dryer Repair)
by DaHadster 1/10/2017 12:25:28 PM(UTC)
