Discuss
Dryer won't start
 in
Dryer Repair
dryer is from 1982, they don't make 'em like this anymore! there is full voltage (115v) at both terminals of
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't start
  #1 (permalink)
Old 06-04-2012, 02:12 PM
Junior Member
LesterS is on a distinguished road
Default Dryer won't start
Model Number: LG5801XKW0   Brand: Whirlpool   Age: More than 10 years
dryer is from 1982, they don't make 'em like this anymore! there is full voltage (115v) at both terminals of the thermal fuse located in lint exhaust duct and at both terminals of the door switch. no power present (see below) at main on/off switch (3 terminal push switch). I recorded about 9.5v at terminals of all the following:
- (3) thermostats in lint duct
- (1) thermostat in heat duct
- appropriate terminals of main on/off switch in each position
- both terminals of selector switch in main panel
- all but (1) terminal of the timer assy, which recorded near 0v no matter what position timer was set at (all other terminals of this timer assy recorded the same 9.5v)
about 2 months ago replaced magnetic coils assy on gas valve and has been working fine til now.
Ads By Google
Related Models
Whirlpool LG5801XKW0
Whirlpool LG5801XKW1
Whirlpool LG5801XMW0
Whirlpool LG5801XMW1
Whirlpool LG5801XMW2
Whirlpool LG5801XPW0
Whirlpool LG5801XSW0
Whirlpool LG5801XSW1
Whirlpool LG5801XSW2
Whirlpool LG5801XSW3
Whirlpool LG5806XPW0
Whirlpool LG5811XPW0
Whirlpool LG5901XSW0
Whirlpool LG5921XKW0
Whirlpool LG5921XKW1
Whirlpool LG5921XMW0
Whirlpool LG5921XMW1
Whirlpool LG5921XMW2
Whirlpool LG5951XSW0
Frigidaire LG600AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG600AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG600MXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG600MXD2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG600MXD3 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG600MXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG600MXW2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG600MXW3 Wwh(v1) / 27 " Gas Laundry Center
Whirlpool LG6056XSW0
Whirlpool LG6056XSW1
Whirlpool LG6091XSW0
Whirlpool LG6091XSW1
Whirlpool LG6091XTG0
Whirlpool LG6091XTN0
Whirlpool LG6091XTW0
Whirlpool LG6099XSW0
Whirlpool LG6099XSW1
Whirlpool LG6099XTF0
Whirlpool LG6099XTG0
Whirlpool LG6099XTG1
Whirlpool LG6099XTM0
Whirlpool LG6099XTN0
Whirlpool LG6099XTN1
Whirlpool LG6099XTW0
Whirlpool LG6099XTW1
Whirlpool LG6101XSW0
Whirlpool LG6151XSW0
Whirlpool LG6151XSW1
Whirlpool LG6401XKW0
Whirlpool LG6601XKW0
Whirlpool LG6601XPW0
Whirlpool LG6601XSW0
Whirlpool LG6606XPW0
Whirlpool LG6606XPW1
Whirlpool LG6681XKW0
Whirlpool LG6801XPW0
Whirlpool LG6801XSW0
Whirlpool LG6801XTG0
Whirlpool LG6801XTN0
Whirlpool LG6801XTW0
Whirlpool LG6806XPW0
Whirlpool LG6811XPW0
Whirlpool LG6811XSW0
Whirlpool LG6881XSW0
Whirlpool LG6881XSW1
Whirlpool LG6881XTF0
Whirlpool LG6881XTG0
Whirlpool LG6881XTG1
Whirlpool LG6881XTM0
Whirlpool LG6881XTN0
Whirlpool LG6881XTN1
Whirlpool LG6881XTW0
Whirlpool LG6881XTW1
Whirlpool LG6901XKW0
Whirlpool LG7001XKW0
Whirlpool LG7001XMW0
Whirlpool LG7001XMW1
Whirlpool LG7001XMW2
Whirlpool LG7001XPW0
Whirlpool LG7001XSW0
Whirlpool LG7001XTG0
Whirlpool LG7001XTN0
Whirlpool LG7001XTW0
Whirlpool LG7006XPW0
Whirlpool LG7011XPW0
Whirlpool LG7011XSW0
Whirlpool LG7081XSF1
Whirlpool LG7081XSG1
Whirlpool LG7081XSM1
Whirlpool LG7081XSN1
Whirlpool LG7081XSW0
Whirlpool LG7081XSW1
Whirlpool LG7081XTF0
Whirlpool LG7081XTG0
Whirlpool LG7081XTG1
Whirlpool LG7081XTM0
Whirlpool LG7081XTN0
Whirlpool LG7081XTN1
Whirlpool LG7081XTW0
Whirlpool LG7081XTW1
Whirlpool LG7681XMW0
Whirlpool LG7681XPW0
Whirlpool LG7681XSN3
Whirlpool LG7681XSW0
Whirlpool LG7681XSW1
Whirlpool LG7681XSW2
Whirlpool LG7681XSW3
Whirlpool LG7686XPW0
Whirlpool LG7686XPW1
Whirlpool LG7701XWN0
Whirlpool LG7701XWW0
Whirlpool LG7761XWN0
Whirlpool LG7761XWW0
Whirlpool LG7801XKW0
Whirlpool LG7801XKW1
Whirlpool LG7801XMW0
Whirlpool LG7801XMW1
Whirlpool LG7801XMW2
Whirlpool LG7801XPW0
Whirlpool LG7801XSW0
Whirlpool LG7801XSW1
  #2 (permalink)
Old 06-04-2012, 03:36 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Unplug the dryer. Remove one lid off the thermal fuse and check it for continuity.
If you are reading the 115V across the fuse that means it's open.
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-04-2012, 03:54 PM
Junior Member
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Simon.
I'm not an electrician so my terminology might not be precise, I'll try to explain better what I did......with the machine plugged in and both wire leads attached to the thermal fuse, I checked each terminal individually with a probe and the other probe to ground on the machine, in each case I got a full 115v reading so I assumed it is closed/good....I also checked it previously out of the machine for continuity and it was a bit fussy, but the more I checked it (making sure I had good contacts) the more I concluded that it tested positive for continuity. The same testing method was used for the two terminals of the door switch (each terminal individually and ground) which showed 115v on each side. All the other thermostats/controls mentioned in first post were tested the same way, each terminal individually to ground checking for voltage.
  #4 (permalink)
Old 06-04-2012, 04:32 PM
Expert
Default
Hi.
Please except my apologies, for some reason I've decided that you have the electric dryer.
I did the research and couldn't find the wiring diagram, but you should have one.
But first check the door switch actuator it may be just broken off.
Next according the wiring diagram check the timer's contacts for continuity.
Unfortunately I can't be more help without the diagram.
Simon.
__________________
  #5 (permalink)
Old 06-04-2012, 04:42 PM
Junior Member
Default
Hi.
Simon.
ok no problem.....the door switch is in tact and good. the timer has about 5 terminals on it, how do I check them for continuity? when I checked them for voltage, they all showed approx 9.5v except for one that was near 0v (with machine plugged in). so this looked to me like power was going from cord to the thermal fuse first, then door switch, but not to main switch or timer?......I do have a diagram which I can scan/email to you?
  #6 (permalink)
Old 06-04-2012, 08:03 PM
Expert
Default
Please do so.
Simon.
__________________
  #7 (permalink)
Old 06-04-2012, 08:32 PM
Junior Member
Default
Please do so.
Simon.
to what email address?
  #8 (permalink)
Old 06-05-2012, 09:27 AM
Administrator
APP Team
Adam / APP Team is on a distinguished road
Default
Hey Guys,
Hope you two dont mind me chiming in here.
If you need to share photos you can hit the "Go Advanced" button and click on "Manage Attachments" to attach a file from your computer.
Its much easier and safer for the both of you. Besides.. you guys will be helping many others out here with the same problem
If you have any questions feel free to ask. Im here to help.
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices.
Thank you for supporting our free repair help forum.
  #9 (permalink)
Old 06-05-2012, 10:07 PM
Junior Member
Default
attached is the wiring diagram......power (115v) is present into and out of the thermal fuse and the door switch
  #10 (permalink)
Old 06-06-2012, 12:01 PM
Expert
Default
Hi.
According the diagram there are four things to check:
- thermal fuse
- door switch
- timer contacts Y-BG should be closed
- start switch contact NO should read 120v to the ground when pushed
All continuity checks must be done with one wire off.
Try to install the jumper wire on three first parts (one at the time).
If all of this checks OK - replace the motor.
Here are the breakdown diagram and http://www.appliancepartspros.com/pa...odel_id=252208
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dryer Repair 0 03-28-2011 03:21 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dishwasher Repair 0 03-28-2011 12:13 PM
Dryer will not start - will power up, but when push the start button, will not start perduena Dryer Repair 0 07-12-2010 07:14 PM
dryer start button flashing and not clicking to start dryer lawfamily Dryer Repair 0 06-21-2010 07:43 PM
