| » LED light indicates Locked rotor? |
Model Number: wjrr417og1ww Brand: GE Age: 1 - 5 years
You either have a bad motor or bad mode shifter or you may have rogue error light.
First put everything back together. If you are getting the flashing lights, make sure the washer is off and disconnect all power for at least a minute. Then plug it in and raise and lower the lid five or six times quickly. Then see if the error code has cleared out and if the machine works. If it does not, take off the belt and see if the big pulley on the transmission like thing will move. If it will the motor is bad, if it does not move, the mode shifter (which replaces a transmission in this machine) is bad. Good luck.
__________________
Thanks sid,
I'll try it tomarrow morning. Then I'll post my findings. If nothing else, I plan to see the appliance repair shop tomarrow and see how much a replacement motor will cost. The big pulley moved freely before I took the motor off the unit. I though maybe this was the problem. Now, I'm thinking otherwise. Will see. |
| Display Modes | |
| Door locked-lock light on - | mslinda41 | Oven Repair (including Ranges and Cooktops) | 2 | 10-21-2009 12:17 PM |
| Electronics locked - green light flashing | blakelv | Dishwasher Repair | 1 | 03-22-2009 12:10 PM |
| GE washer repair-LOCKED ROTOR | rgdj | Washer Repair | 0 | 07-26-2008 09:20 AM |
| Controls locked light will not deactivate. | Dan Hogan | Dishwasher Repair | 0 | 03-31-2008 12:03 PM |
| locked light on washer does not start | tomminil | Dishwasher Repair | 1 | 03-29-2008 11:53 AM |
