| » Replacing Kitchen Aid (Whirlpool) gas valve coils (Solenoid Kit) |
Model Number: KGYS750GQ1 Brand: Kitchen Aid Age: 5 - 10 years
My dryer does not heat. The igniter glows for a few seconds and then goes out. I ordered the gas valve coils (Solenoid Kit), but was informed it does not come with directions.
1. I think I need to remove the drum. Does this only involve removing the belt from the pulley? 2. Do I need to shut off the gas valve? If so, can I shut off the valve outside the dryer that is on the basement wall? If I need to shut off the valve inside the dryer, I need instructions as to what it looks like, where it is and how to turn it, including what tool to use. Do I need to test for gas leak when I turn it back on? 3. Please provide directions for accessing, removing and replacing the solenoids. I prefer to remove as few parts and screws as necessary. Hopefully, I won’t need to touch the igniter, since that gray area is so sensitive. Do the Solenoids simply pull out and push in by hand or do I need to use a needle nose pliers? Thanks for the assistance. Ads By Google Related Models Last edited by christian1959 : 07-21-2009 at 04:22 AM. |
You can use the instructions from one of our previous posts: How to open dryer to replace coils on gas valve
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KGYS750GQ1 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| solenoid for valve | webmeister | Refrigerator & Freezer Repair | 0 | 07-27-2009 06:38 PM |
| Valve, solenoid | dgetswet | Refrigerator & Freezer Repair | 0 | 06-09-2009 06:16 PM |
| Access to Hot Water Solenoid Valve | windblown | Washer Repair | 2 | 03-10-2009 02:07 PM |
| Kitchen Aid / Whirlpool drain check valve no longer available | KenSt | Dishwasher Repair | 3 | 10-29-2008 03:20 AM |
| Gas Valve Solenoid Coil | Teewaddy | Dryer Repair | 5 | 10-25-2007 04:45 PM |
