| » Dryer won't heat |
Model Number: LER5636JQ0 Brand: Whirlpool Age: 5 - 10 years
I purchased a Digital Multimeter and tested the thermastat's, Thermal fuse and power coming in and all seem to be okay. The heater element had a reading of 9.7 on the Multimeter. The other parts read near zero. With the 9.7 reading can I assume I need to replace the heater element?
Thanks!! Related Models |
Hi Tpyle
If everything else checks out, the heating element would seem a good bet. That reading is a little low so I think it is worth taking a chance, particularly since the element is not too expensive. Good luck, let us know how it works out.
__________________
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 0 | 12-06-2009 01:58 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
| Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
