jkryzak
#1 Posted : Thursday, May 21, 2009 5:10:24 PM(UTC)
jkryzak
I went to turn om my Matag MDG8400AW dryer and it would not start. The damp light came on, but the dryer did not start tumbling or warm up. I turned the knob to the "extended tumble" position and the dryer starts up and tumbles (no heat). What's wrong? What steps should I go through to diagnose the problem and find the bad component? I tested the continuity on the ignitor and thermal fuse. Haven't found the problem yet. Need Help! Jim
sidfink43
#2 Posted : Monday, May 25, 2009 6:10:21 AM(UTC)
sidfink43
Probably a problem in the gas system if you have checked out all of the termal fuses and thermostats.
Here is the service manual.
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
Good luck.
jkryzak
#3 Posted : Tuesday, May 26, 2009 1:56:10 PM(UTC)
jkryzak
It turned out to be burned contact switches in the timer. Thanks for the service manual.
sidfink43
#4 Posted : Tuesday, May 26, 2009 2:19:22 PM(UTC)
sidfink43
Glad you found the problem, and thanks for updating us. A lot of folks view this site and your posting.
jkryzak
#5 Posted : Tuesday, June 2, 2009 11:36:08 AM(UTC)
jkryzak
Now I noticed another problem. The new timer stays in the same position as the dryer runs, and the dryer does not shut off when the clothes are dry. Is the new timer bad? Shouldn't it rotate itself to the off position as time goes by?
sidfink43
#6 Posted : Tuesday, June 2, 2009 1:09:49 PM(UTC)
sidfink43
Does this happen on timed dry, or automatic on on both?
jkryzak
#7 Posted : Wednesday, June 3, 2009 2:08:22 AM(UTC)
jkryzak
Good idea to try that. Yes the timer does advance during timed dry. Did something go wrong with the intelidry? It was working before the original timer went bad.
sidfink43
#8 Posted : Wednesday, June 3, 2009 5:50:02 AM(UTC)
sidfink43
In automatic mode the moisture sensor prevents the timer motor from running until the clothes are nearly dry. Check all the wires coming into the timer and see if you can find the problem.
Good luck.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
