Sandysalter
#1 Posted : Saturday, October 29, 2011 2:41:21 PM(UTC)
Sandysalter
I just finished replacing the thermal cut-off and hi-limit kit, part #AP3094244, in my dryer but it still isn't heating up. What else could it be? p.s. I didn't use the red/white wire that came in the package. Would that make a difference?
#2 Posted : Sunday, October 30, 2011 2:33:33 AM(UTC)
See the attachment for the wiring diagram.
[COLOR="DarkRed"]
I just finished replacing the thermal cut-off and hi-limit kit, part #AP3094244, in my dryer but it still isn't heating up. What else could it be?[/COLOR]
I cannot say you have to troubleshoot it..
Why did you replace it?
Did one of the parts measure bad?
Have you checked the power to the unit? The heating coil requires the full 240 volts.
Have you checked the other parts in the heater circuit for continuity?
[COLOR="DarkRed"]
p.s. I didn't use the red/white wire that came in the package. Would that make a difference?[/COLOR]
Again I cannot say.
It depends how you wired it in, see the wiring diagram.
The kit is universal so the red wire is not required on all units.
File Attachment(s):
TEDX540.pdf (506kb) downloaded 3 time(s).
Sandysalter
#3 Posted : Sunday, October 30, 2011 9:23:33 AM(UTC)
Sandysalter
[COLOR="DarkRed"]
[COLOR="DarkRed"]
Again I cannot say.
I decided to replace it after researching the q&a forums on this website; this was the same advice given over and over for my same symptons. My dryer drum turns, air is blowing sufficiently from the dryer to the vent, and from the vent to outside (no blockages). There is sufficient power to the unit. I have not checked any other parts in the heater circuitry. I put everything in as was directed on the diagram. I did not replace my red/white wire and the new one, so not sure it that's the problem?? I wouldn't think keeping the old wire still attached would be the problem; I thought it might be more like a heating element, or fuse?? Sorry for the initial vague message, but appreciate any advice you can give me.
#4 Posted : Sunday, October 30, 2011 10:15:19 AM(UTC)
Since all you did was replace the devices not replacing the wire itself should not be required.
Only way to properly troubleshoot is with a meter.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Coin operated Gas Dryer doesn't heat on 2nd cycle (Dryer Repair)
by sup 7/13/2017 9:44:31 AM(UTC)
*** HELP!! GE Dryer Doesn't Heat *** (Dryer Repair)
by SkyNet3 2/25/2016 12:46:10 PM(UTC)
Dryer doesn't heat (Dryer Repair)
by SteveDB 4/16/2013 10:47:38 AM(UTC)
Kitchenaid dryer doesn't heat (Dryer Repair)
by Snakebone 11/8/2012 11:40:23 AM(UTC)
by Snakebone 11/8/2012 11:31:10 AM(UTC)
Maytag Neptune-Dryer doesn't heat up (Dryer Repair)
by See Jane Run! 7/24/2012 3:27:30 PM(UTC)
Dryer doesn't heat properly. (Dryer Repair)
by pnoe 2/19/2012 1:18:10 PM(UTC)
by jammaker 5/11/2011 7:59:33 AM(UTC)
Maytag Neptune Gas dryer doesn't heat (Dishwasher Repair)
by kmc1214 4/8/2011 8:00:44 AM(UTC)
Anana Dryer Doesn't Heat (Dryer Repair)
by dhs51 2/8/2011 3:26:11 PM(UTC)
Electric Dryer Doesn't heat up (Dryer Repair)
by yomeropistolero 1/16/2011 9:57:44 PM(UTC)
Dryer doesn't heat properly (Dryer Repair)
by kevin.m.elkin@rrd.com 12/7/2010 7:41:41 PM(UTC)
by briggins8 10/9/2010 3:48:45 PM(UTC)
Gas Dryer doesn't heat up - but that isn't my issue (Dryer Repair)
by mitch8 10/6/2010 11:04:27 AM(UTC)
Dryer doesn't heat up and moisture sensor not indicating wet clothes (Dryer Repair)
by Joan Cartier 10/3/2010 5:58:52 AM(UTC)
