I just replaced the thermal fuse and it still won't start. The lights turn on on the front but when i push the start button it only beeps. Some of the options on the left of the start knob had stop working but the timed wash would work.
I could not find info on the given model number gew9250w1. The following is for gew9250pw1. Here are your parts Replacement parts for WHIRLPOOL GEW9250PW1 ELECTRIC DRYER | AppliancePartsPros.comSee the attachment for the tech sheet. At the top of the list would be the door switch and the belt switch. Try some of the diagnostics. The old problem of some functions not working is worrisome as the points to a bad control board. |
THIS FORUM IS DEAD!!!!!!! |
