Discuss
Dryer won't heat
 in
Dryer Repair
I have a Kenmore Elite Dryer (Model# 110.73952102). I recently replaced the electronic panel after one of the resistors
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't heat
  #1 (permalink)
Old 12-01-2007, 10:07 PM
sdemiss sdemiss is offline
Junior Member
sdemiss is on a distinguished road
Question Dryer won't heat
Model Number: 110.73952102   Brand: Kenmore   Age: 1 - 5 years
I have a Kenmore Elite Dryer (Model# 110.73952102). I recently replaced the electronic panel after one of the resistors was fried and switched the heat relay with the motor relay. Now everything else works except the fact that there is no heat. I also opened the kick plate to clean a little bit and found a loose red/yellow wire that originates from the moisture sensor @ the electonic panel. I donot know if it should be left like that, or be attached to something?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-02-2007, 09:47 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Why did you switch the motor relay with the heater relay?
The red/yellow wire from the moister sensor should be connected to the P2-4 terminal on the control board.
Regarding the heat problem, you have to check the heater strip circuit and perform all tests in accordance with the technical documentations.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer won't heat bullas5 Dryer Repair 0 11-23-2007 04:03 PM
dryer won't heat rmzj Dryer Repair 0 11-23-2007 01:31 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
dryer no heat pdowney Dryer Repair 2 10-18-2007 07:32 AM
gas dryer with no heat lz7274 Dryer Repair 1 08-22-2007 05:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
