I have a maytag MDE 9700 AYW, and the dryer will not start. I have power, and it will try to start then flash an upside down F followed by a 5. I followed the instructions someone posted about reading the codes and it shows an eror code of 1 with the locked button lit up next to it. I cleared the codes and the dryer will start and run for 30 seconds then stop and flash F5. I took out the Thermistor, and it was soaked as well as the vent. I checked the ohms on the two posts and my craftsman auto range read 13.4. What do I need to do now? It still will not start unless I clear the codes.
