dryer was working put in clothes & dryer sheet & started. Wife came home clothes were not dry & dryer wouldn't start. Checked breaker confirmed power to plug. read other posts & assumed door switch had gone. took apart to diagnose & vacuum lint & also found belt broken. Dryer was a little noisy. Should I install Dryer repair kit while apart? Would broken belt stop dryer from running or should I replace door switch now while apart? Scot
