I assumed I need a heating element, or is there something else that could be causing my electric dryer not to heat. Its spinning fine.
Originally Posted by: swtpotato3 I assumed I need a heating element, or is there something else that could be causing my electric dryer not to heat. Its spinning fine. Swtpotato, Have you checked and reset both breakers at the breaker panel ? or ch Try that first, then consider a heater element. There are other components to consider, but the heater element is one of the more common problems.
