Derrick
#1 Posted : Monday, October 22, 2007 11:48:02 AM(UTC)
Derrick
Hi I am trying to fix a ladys dryer who can't aford a serviceman, The dryer will not heat. The igniter dosn't glow when you first turn on the dryer. I checked it with an ohm meter and got a reading of 109 which from what I have read is good. My question is, if the igniter checks good what do I check before the igniter.
#2 Posted : Monday, October 22, 2007 4:43:05 PM(UTC)
Hi Derrick
Most likely the problem with your dryer is a blown thermal fuse which is located under the rear panel. Check the thermal fuse for continuity and if it's open, replace it. Per the manufacturer instructions, if the thermal fuse is blown, the thermistor has to be replaced too. Also check the vent for any clogs and the air flow restrictions.
The thermal fuse
UserPostedImage
The thermistor
UserPostedImage
- The part number for the thermal fuse AP3133489
- The part number for the thermistor AP3083396
Good luck.
Derrick
#3 Posted : Tuesday, October 23, 2007 4:43:55 PM(UTC)
Derrick
Thank Gene,
We checked the thermal fuse and the meter read zero. We are totally baffled. We checked to see if the ignitor was getting 120 v and we did not get a reading. Please Help!!!!
#4 Posted : Tuesday, October 23, 2007 6:56:26 PM(UTC)
Hi Derrick
Next part you should check for continuity is the flame sensor. If it's open - replace it.
UserPostedImage
- The part number for the flame sensor AP2910747
#5 Posted : Wednesday, October 24, 2007 3:31:37 AM(UTC)
Check the two pin connector that feeds voltage to the igniter/gas valve combo. If no voltage there, you have problems in some other component, maybe the timer or cycling thermostat.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
