gretle
#1 Posted : Friday, December 12, 2008 10:54:10 AM(UTC)
gretle
When I push in control dial the dryer does not start, but I can hear the timer come on. The door is closed and the open/close button seems to work fine (the light comes on). A couple days prior to this, the dryer would not shut off. I could start the dryer and it would run fine through the "more dry", then get stuck while in "less dry", then never shutting off until manually moving the dial. Do you have any suggestions? Any help would be appreciated. Thanks.
gretle
#2 Posted : Friday, December 12, 2008 5:54:57 PM(UTC)
gretle
I disconnected the thermo fuse and temperarily hard wired the connectors together and the dryer started .:) So now I just have to replace the thermo fuse (a $4 part).
#3 Posted : Friday, December 12, 2008 6:59:50 PM(UTC)
Per the manufacturer instructions, if the thermal fuse has blown, the cycling thermostat (on the blower housing) has to be replaced too. Also I would recommend to clean the exhaust line and the air ducts inside the dryer.
- The part number for the cycling thermostat is AP3831088
Here are the break down diagrams for the Maytag dryer Model MDG308DAWW
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Dryer won't start all the time (Dryer Repair)
by DaHadster 1/10/2017 12:25:28 PM(UTC)
