| » Estate Dryer |
A model number might help
I believe you are talking about the door switch activator. There is a switch inside the machine that must be closed for the unit to run. If it is a little clip that has bust off snaps into the door, you will have to replace it. If it is a metal actuator you may be able to re-bend it so the door closes the switch, just be gentle. The actuator is often mounted to the switch which is plastic.
__________________
| Display Modes | |
| estate gas dryer | tmbrinkworth | Dryer Repair | 0 | 10-16-2009 05:40 PM |
| Estate Gas Dryer LP gas | patcalvo | Dryer Repair | 0 | 10-10-2009 10:54 AM |
| Whirlpool estate gas dryer | dryerman101 | Dryer Repair | 3 | 07-27-2009 09:43 AM |
| estate dryer | tmohler | Dryer Repair | 2 | 10-29-2008 05:53 PM |
| Estate Dryer by Whirlpool/Dryer running but no heat | tsm11238 | Dryer Repair | 1 | 11-06-2007 10:47 AM |
