| » Dryer won't start |
A Model Number might help others help you.
Your power to the start button issue depends on how you are measuring it. For instance if you are measuring across the switch's contacts. When open you will see a voltage. When close there is no voltage as the contacts in the switch are a dead short. This is normal.
__________________
Have lots of ideas but finding the right one is the trick. That is why a Model Number comes in handy. Then with a little luck can find a wiring diagram.
Also you did not say how (where are your meter leads) when checking for power. 1. Door Switch 2. Start switch 3. Timer contacts 4. Motor 5 Thermal fuse 6 Half the line missing Not necessarilly in the above order
__________________
I have the meter leads on the black wire at the start Switch. The door switch is working i assume because it shuts the timer off when open and closed. I will get the model number shortly and post it. I will check the fuse as well
| Display Modes | |
| whirlpol dryer won't start-just hums when I push the start button | bdubois | Dryer Repair | 27 | 02-18-2010 07:36 PM |
| HOT POINT DRYER has power but start button doesn't start the dryer. | HOT POINT | Dryer Repair | 1 | 12-17-2009 10:39 AM |
| dryer start but stops when I release start button | vchss360 | Dryer Repair | 7 | 10-20-2009 03:46 AM |
| Kenmore Dryer won't start unless PTS (push to start) button depressed and held | trp | Dryer Repair | 1 | 06-07-2009 06:13 AM |
| dryer start button noise - dryer won't run | brhodes58 | Dryer Repair | 6 | 03-14-2009 02:11 PM |
