Discuss
Whirlpool gas dryer wont heat.
 in
Dryer Repair
Whirlpool gas dryer wont light. Blower and drum work fine. How do I determine if it is the igniter or
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool gas dryer wont heat.
  #1 (permalink)
Old 09-16-2010, 08:18 PM
Junior Member
Ray3059 is on a distinguished road
Exclamation Whirlpool gas dryer wont heat.
Model Number: LGR7646EQ3   Brand: Whirlpool   Age: 5 - 10 years
Whirlpool gas dryer wont light. Blower and drum work fine. How do I determine if it is the igniter or if it something else?
Ads By Google
Related Models
Whirlpool LGR7646EQ3 GAS DRYER
Whirlpool LGR7646EZ0 DRYER
Whirlpool LGR7646EZ1 DRYERS
Whirlpool LGR7646EZ2 GAS DRYER
Whirlpool LGR7646EZ3 GAS DRYER
Whirlpool LGR7646JQ0 GAS DRYER
Whirlpool LGR7646JQ1 RESIDENTIAL DRYER
Whirlpool LGR7646JT0 GAS DRYER
Whirlpool LGR7646JT1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ0 RESIDENTIAL DRYER
Whirlpool LGR7648KQ1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ2 29"GAS DRYER
Whirlpool LGR7648KT0 RESIDENTIAL DRYER
Whirlpool LGR7648KT1 RESIDENTIAL DRYER
Whirlpool LGR7648KT2 29"GAS DRYER
Whirlpool LGR7648PQ0 29" GAS DRYER
Whirlpool LGR7648PQ1 29" GAS DRYER
Whirlpool LGR7648PT0 29" GAS DRYER
Whirlpool LGR7648PT1 29" GAS DRYER
Whirlpool LGR7848DQ0 GAS DRYER
Whirlpool LGR7848DQ1 GAS DRYER
Whirlpool LGR7848DZ0 GAS DRYER
Whirlpool LGR7848DZ1 GAS DRYER
Whirlpool LGR7858AN1 GAS DRYER
Whirlpool LGR7858AN2 GAS DRYER
Whirlpool LGR7858AW0 Residential Dryer
Whirlpool LGR7858AW1 GAS DRYER
Whirlpool LGR7858AW2 GAS DRYER
Whirlpool LGR8620PG0 29"GAS DRYER
Whirlpool LGR8620PG1 29"GAS DRYER
Whirlpool LGR8620PW0 29"GAS DRYER
Whirlpool LGR8620PW1 29"GAS DRYER
Whirlpool LGR8646LG0 RESIDENTIAL DRYER
Whirlpool LGR8648LG1 29"GAS DRYER
Whirlpool LGR8648LQ0 RESIDENTIAL DRYER
Whirlpool LGR8648LW0 RESIDENTIAL DRYER
Whirlpool LGR8648LW1 29"GAS DRYER
Whirlpool LGR8648PG0 29"GAS DRYER
Whirlpool LGR8648PG1 29" Gas Dryer
Whirlpool LGR8648PQ0 29" GAS DRYER
Whirlpool LGR8648PQ1 29" Gas Dryer
Whirlpool LGR8648PW0 29"GAS DRYER
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0 GAS DRYER
Whirlpool LGR8857EQ1 DRYERS
Whirlpool LGR8857EQ2 GAS DRYER
Whirlpool LGR8857EQ3 GAS DRYER
Whirlpool LGR8857EZ0 GAS DRYER
Whirlpool LGR8857EZ1 DRYERS
Whirlpool LGR8857EZ2 GAS DRYER
Whirlpool LGR8857EZ3 GAS DRYER
Whirlpool LGR8858DQ0 GAS DRYER
Whirlpool LGR8858DQ1 GAS DRYER
Whirlpool LGR8858DZ0 GAS DRYER
Whirlpool LGR8858DZ1 GAS DRYER
Whirlpool LGR8858EQ0 GAS DRYER
Whirlpool LGR8858EQ1 DRYERS
Whirlpool LGR8858EQ2 GAS DRYER
Whirlpool LGR8858EQ3 GAS DRYER
Whirlpool LGR8858EZ0 GAS DRYER
Whirlpool LGR8858EZ1 DRYERS
Whirlpool LGR8858EZ2 GAS DRYER
Whirlpool LGR8858EZ3 GAS DRYER
Amana LGS10AW WASHER-TOP LOADING
Amana LGS19AW DRYER- GAS
Amana LGS33AW DRYER- GAS
Amana LGS34AW WASHER-TOP LOADING
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AQ0 Residential Dryer
Whirlpool LGT5434AW0 Residential Dryer
Whirlpool LGT5436AW0 Residential Dryer
Whirlpool LGT5624BN0 GAS DRYER
Whirlpool LGT5624BN1 GAS DRYER
Whirlpool LGT5624BN2 GAS DRYER
Whirlpool LGT5624BQ0 GAS DRYER
Whirlpool LGT5624BQ1 GAS DRYER
Whirlpool LGT5624BQ2 GAS DRYER
Whirlpool LGT5624BW0 GAS DRYER
Whirlpool LGT5624BW1 GAS DRYER
Whirlpool LGT5624BW2 GAS DRYER
Whirlpool LGT5624DQ0 GAS DRYER
Whirlpool LGT5624DQ1 GAS DRYER
Whirlpool LGT6634AN1 DRYER
Whirlpool LGT6634AN2 GAS DRYER
Whirlpool LGT6634AQ0 GAS DRYER
Whirlpool LGT6634AQ1 GAS DRYER
Whirlpool LGT6634AQ2 GAS DRYER
Whirlpool LGT6634AW0 Residential Dryer
Whirlpool LGT6634AW1 DRYER
Whirlpool LGT6634AW2 GAS DRYER
Whirlpool LGT6634DQ0 GAS DRYER
Whirlpool LGT6634DQ1 GAS DRYER
Whirlpool LGT6634DZ0 GAS DRYER
Whirlpool LGT6634DZ1 GAS DRYER
Whirlpool LGT6638AN1 GAS DRYER
Whirlpool LGT6638AN2 GAS DRYER
Whirlpool LGT6638AQ2 GAS DRYER
Whirlpool LGT6638AW0 Residential Dryer
Whirlpool LGT6638AW1 GAS DRYER
Whirlpool LGT6638AW2 GAS DRYER
Whirlpool LGT6638DQ0 GAS DRYER
Whirlpool LGT6638DQ1 GAS DRYER
Whirlpool LGT6638DZ0 GAS DRYER
Whirlpool LGT6638DZ1 GAS DRYER
Whirlpool LGT7646AQ0 Residential Dryer
Whirlpool LGT7646AQ2 GAS DRYER
Whirlpool LGT7646AW0 Residential Dryer
Whirlpool LGT7646AZ2 GAS DRYER
Whirlpool LGT7646DQ0 GAS DRYER
Whirlpool LGT7646DQ1 GAS DRYER
Whirlpool LGT7646DZ0 GAS DRYER
Whirlpool LGT7646DZ1 GAS DRYER
Whirlpool LGT7646EQ0 GAS DRYER
Whirlpool LGT7646EQ1 DRYERS
Whirlpool LGT7646EQ2 GAS DRYER
Whirlpool LGT7646EQ3 GAS DRYER
Whirlpool LGT7646EZ0 GAS DRYER
Whirlpool LGT7646EZ1 DRYERS
Whirlpool LGT7646EZ2 GAS DRYER
Whirlpool LGT7646EZ3 GAS DRYER
  #2 (permalink)
Old 09-17-2010, 05:32 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Quote:
Here is what I would do first. Unplug the dryer, and take the back off. Once the back is off, you will see a small thin, white part. It will be an inch and a half long, by a half inch wide, and will be held in by one screw, and have 2 wires coming to it. Take the 2 wires off, and put the terminal ends of the wires together, and put some tape around them to keep them together, and to be sure they don't hit metal, and then plug the dryer in and see if it works. If so, DO NOT !!!! Run the dryer that way. That is a saftey. This is for diagnostics only. If it does not work, let me know. If it does worklet me know. Tom ********************************************
  #3 (permalink)
Old 09-17-2010, 07:15 AM
Junior Member
Default
I checked continuity in the fuse it's good. No flame
  #4 (permalink)
Old 09-17-2010, 07:43 AM
Senior Expert
APP Volunteer
Default
jump out the flame sensor on the left side of the flame tube, and see if the ignitor comes on. If not, replace the ignitor. Tom. ********************************************
  #5 (permalink)
Old 09-17-2010, 09:43 AM
Junior Member
Default
where is the igniter located?
  #6 (permalink)
Old 09-20-2010, 10:02 AM
Junior Member
Default
I have removed the ignitor and ordered a new one this morning. Should I check resistance, if what should it read.There is contiunuity through the radiant sensor. I presume its normally closed.
  #7 (permalink)
Old 09-21-2010, 04:23 AM
Senior Expert
APP Volunteer
Default
You know Ray, sometimes on some conponents, taking a resistance is not totally accurate. That is why on those gas conponents, I always jump them out. Then you know for sure. It sounds like you have it. Let me know. Tom
  #8 (permalink)
Old 09-22-2010, 02:39 PM
Junior Member
Default
I got the new ignitor today and installed it. Still no flame. What now? Check the coils or replace them? What else can it be?
  #9 (permalink)
Old 09-23-2010, 04:26 AM
Senior Expert
APP Volunteer
Default
Ray, you have to do this my way, so we can get you a dryer. If the ignitor comes on and there is no gas, it is most likely the coils, or possibly the whole gas valve. If the ignitor does not come on, then do it this way. We are going to systematically jump out each conponent till the gas comes out. Now unplug the dryer, and take the 2 wires off of the thermal fuse (The little white one in the back) Put the two terminal ends together, and put some tape around it, so it does not hit metal, and keeps the terminal ends together, plug it in, and see if it works. If so, replace the thermal fuse. If not, unplug the dryer, and put the wires back on the thermal fuse, and then go inside, and do the same thing to the the flame sensor. Then plug it back in, and If it works replace the flame sensor, if not, then the coils on the gas valve, or the whole gas valve is the issue. Do it this way. Also, tell me if the ignitor comes on. Tom
  #10 (permalink)
Old 09-23-2010, 09:04 AM
Junior Member
Default
Tom
I have jumped out all components to the except the coils. Ignitor comes on momentarily but the gas does not flow. How do I determine if it is the coils or the valve itself?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool dryer wont heat Stuckinmud15 Dryer Repair 1 08-15-2010 06:37 AM
electric whirlpool dryer,wont heat to dry clothes cindymerritt Dryer Repair 1 07-13-2010 11:11 AM
Whirlpool Elec Dryer wont heat up Canute Dryer Repair 8 02-26-2010 03:06 AM
Whirlpool Gas Dryer Wont Heat SISSY1 Dryer Repair 0 10-20-2009 08:20 PM
Whirlpool electric dryer wont heat itucker Dryer Repair 5 11-17-2008 05:03 PM
