pete-94
#1 Posted : Monday, September 13, 2010 7:48:51 AM(UTC)
pete-94
dryer runs all the time drys great just doesnt shut off amd timer doesnt move
#2 Posted : Tuesday, September 14, 2010 12:13:07 AM(UTC)
Here are the parts
Replacement parts for WHIRLPOOL LEQ9508LW0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406661.pdf
Does it do this in both auto and timed dry modes.
The timer motor gets power from different circuit paths in the modes (Timer Switch 3). Direct in timed dry (Timer Switch 3 closed). From the electronic control (moisture sensor) (Timer Switch 3 open).
If it does not advance in either mode odds are the timer motor is shot.
Check it with a meter, if it gets 120 volts in timed dry and does not advance it is toast.
If it does advance in timed dry, clean the moisture sensor (Item 30 in Section 3). Isopropyl alcohol works well but a damp cloth also often works.
Be sure to dry the sensor when clean.
The way this works is there are 2 metal strips, if there is moisture between the strips a circuit path for a small electrical current is there. The board senses this and the unit does not advance as the clothes are still wet.
When dry there is no moisture, no circuit path, the unit senses this and advances the timer.
If there is dirt between the strips, it creates a circuit path and the unit always thinks the clothes are wet and does not advance the timer.
pete-94
#3 Posted : Tuesday, September 14, 2010 4:46:10 AM(UTC)
pete-94
thanks for the help
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
Whirlpool dryer---need to hold start button several seconds (Dryer Repair)
by pjlarivi 2/13/2021 10:44:25 AM(UTC)
