When the dish washer is filling and running, I hear a noise like a screw rattling around. I can't place the noise in the motor on the bottom or the inlet valve for the water supply. Is it ok to spray wd 40 on the propeller that spins to see if this quiets the noise? or Do you think the rattling noise can be from the intake valve. I think replacing the intake valve is less costly and would be willing to try this before having a pro come in. Sorry for the long post, but I would like to fix this myself. Thanks, Bill
