| » GE profile dishwasher won't drain |
Model Number: GSD5330 Brand: GE Age: 1 - 5 years
Not sure of the exact model number. The sticker is missing from the inside of the door. Owners manual lists EDW2020,30,50,60, GSD 5110, 12, 20, 20, 32, 14, 24, 34, GSD5310, 20, 30, 50, 60. Problem started of as intermittent. Had a repair guy come out an look at. He suggested the control board was bad and we would be better off buying a new dishwasher. I replaced the control board and it still did not drain. Then checked the drain tube to the disposal. It appeared to be about 75% plugged on the disposal end. Replaced the hose and it still did not drain. I think the hose got plugged/dirty during the 2 month we did not run the dishwasher but continuted to use the disposal. Then pulled the drain pump. It appears to run ok when you apply power to it while it is sitting on the bench. I can feel it vibrating when it is going through the drain cycle. Then replaced the check valve assembly and it still does not drain. Then opened the door during the drain cycle to ensure the spring loaded valve was down and water was available to the drain side during the drain cycle. I'm confused! Help.
Did you see any blinking status indicator lights during a cycle or at the end of it?
__________________
Professional appliance repair in Los Angeles, California. |
The control board has some self diagnosis options and the status indicator lights are blinking it could tell you what is wrong.
The start/reset blinking light is normal if you interrupt the cycle. Gene.
__________________
| Display Modes | |
| GE Profile washer doesn't drain | shellface | Washer Repair | 6 | 01-05-2009 11:54 AM |
| GE Profile Dishwasher | Tim1539 | Dishwasher Repair | 9 | 04-02-2008 07:40 PM |
| dishwasher won't drain | paulrrtcpft | Dishwasher Repair | 1 | 02-19-2008 05:13 PM |
| GE Profile DW won't drain or spray | JimChooz | Dishwasher Repair | 3 | 02-18-2008 08:09 PM |
| ge profile dishwasher | barbariano298 | Dishwasher Repair | 1 | 01-25-2008 11:31 AM |
