Discuss
Dishwasher won't drain
 in
Dishwasher Repair
Help! My Frigidaire won't drain after the wash cycle is complete. It was installed in 2002, I have not
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher won't drain
  #1 (permalink)
Old 03-05-2008, 08:39 AM
pullmyfinger pullmyfinger is offline
Junior Member
pullmyfinger is on a distinguished road
Unhappy Dishwasher won't drain
Model Number: FDB635RFR5   Brand: Frigidaire   Age: 5 - 10 years
Help! My Frigidaire won't drain after the wash cycle is complete. It was installed in 2002, I have not installed a new disposal, & the is no obstructions. I replace the drain valve & solonoid to no avail. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-05-2008, 07:10 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Quote:
What did you replace? I did not find the drain valve nor the solenoid on your dishwasher parts list.
I would recommend to remove the drain pump and check it and the drain hose for a clog.
Here are the break down diagrams for the Frigidaire dishwasher Model FDB635RFR5
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-06-2008, 06:53 AM
Junior Member
Default
I'm an idiot Gene! I found a blockage. Appeared to be mashed potatos! It was the drain pump I replaced (for nothing). Thanks for the help!
  #4 (permalink)
Old 03-06-2008, 11:41 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
  #5 (permalink)
Old 03-08-2008, 03:24 PM
frankASR frankASR is offline
Junior Member
frankASR is on a distinguished road
Default fridgaire dishwasher
mine always leaves water up to the heating element after com[pleted cycle ,checked loop ,it looks fine,havent checked filter or pump,does it have a filter? is it that round part in bottom with vents around? insine of tub?..... help please
frank
  #6 (permalink)
Old 03-09-2008, 03:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Frank,
In order to provide most accurate advise I need the complete model number of the dishwasher.
__________________
  #7 (permalink)
Old 03-10-2008, 11:26 AM
Junior Member
Default
Like mine, you might not see the obstruction. Take the hose off at both ends & try blowing air through the line. If you can't, obviously you have a blockage. Don't do what I did though! Drain as much water out of the unit before you disconnect it at the dishwasher! This way you won't end up with water all over the floor & dripping into the basement!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher won't drain walknite Dishwasher Repair 4 11-20-2008 04:08 PM
dishwasher won't drain paulrrtcpft Dishwasher Repair 1 02-19-2008 05:13 PM
dishwasher drain problem roger1477 Dishwasher Repair 1 02-02-2008 03:37 AM
Bosch Dishwasher won't drain reisman Dishwasher Repair 4 12-27-2007 03:50 AM
dishwasher won't drain ddavis Dishwasher Repair 1 11-25-2007 05:47 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
