boboss
#1 Posted : Saturday, January 24, 2015 1:23:06 PM(UTC)
boboss
Hello,
my dishwasher has a heating issue due to the standard self test I ran on the unit. This model was the one with the 10A relay that some people on this forum upgraded to a 12A. I can see the burn mark from the old relay on the board.
I ordered the part at digi-key and just before I was about to install it (double checking the old part specs in the board) I noticed that I must have sourced the wrong part by mistake. My new relay from digikey is 6V, where the part to be replaced is 12V.
The question i have is, which is the appropriate upgraded 12A relay to use for this? finding the right part on digikey is daunting if you don't know what you are looking for. Is this the correct part after all?
the original part on the OEM relay on my board is is this, a AJS1311
JS1-12V Datasheet(PDF) - Nais(Matsushita Electric Works)
JS1-12V-F Panasonic Electric Works | 255-2080-ND | DigiKey
the one i ordered from digikey was this
T7CS5D-06 TE Connectivity | PB336-ND | DigiKey
thanks for your help in advance. could anyone in the know please point me to the correct part?
boboss
#2 Posted : Monday, January 26, 2015 7:30:54 AM(UTC)
boboss
please does anyone have an answer for this?
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
Replacing a stacking Bosch Axxis+ Washer (Washer Repair)
by DonLafontaine 3/22/2024 3:59:06 AM(UTC)
Bosch SHP88PW55N water softener issue / replacement (Dishwasher Repair)
by jgoode0417 3/13/2024 8:03:16 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Blows fuse when door is closed (Bosch HMC80251UC) (Microwave Repair)
by mana 1/13/2024 6:06:57 PM(UTC)
Bosch dishwasher troubleshooting (Dishwasher Repair)
by Dan T in SD 12/7/2023 2:38:23 PM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
Bosch ventless dryer sump pump not working (Dryer Repair)
by mdavidson 11/18/2023 2:22:57 AM(UTC)
Bosch Dishwasher intermittently leaking on lower right of door (Dishwasher Repair)
by jjtrinva 11/5/2023 9:30:06 AM(UTC)
Bosch Range - gibberish on display (Oven Repair (including Ranges and Cooktops))
by rafearcher 10/23/2023 11:36:00 AM(UTC)
Bosch Induction Cooktop NIT3065/UC Non-Responsive (Oven Repair (including Ranges and Cooktops))
by trishglxk 10/3/2023 9:18:30 AM(UTC)
Mystery Bosch Part Number (Dishwasher Repair)
by Guest 9/1/2023 2:04:15 PM(UTC)
Bosch Dishwasher Model SHE3AR56UC/07 (Dishwasher Repair)
by EDK1747 8/30/2023 7:42:58 AM(UTC)
Bosch Dishwasher SHE3AR56UC/07 (Dishwasher Repair)
by Guest 8/27/2023 11:27:21 AM(UTC)
